Lisp to place in a polyline blocks and numbering attribute
pagano_edil
pagano_edil
Hi, this is my first post, sorry for any inconvenience that may occour.
I have a polyline/arc where i need to place 9 blocks, each at the same distance(like when u use the command divide), each one of these blocks has multiple attributes, i need to number one these attributes from point a to point b as a-01 for block1, a-02 for block2, etc...
There is a way to do it? I saw the lsp made by leemac "incremental numbering suite" that allow to do something similar but u can't place multiple block in a curved polyline, you can only make a straight array.
Thanks a lot. I placed an example file to be more clear.
3wood
You can do it following steps below:
1. Insert your block 'A', rotate and scale it properly, and fill the attribute with the first number. In your case, it is "a-01".
2. Making a dummy block 'B' containing the block 'A' inserted in Step 1 with the same insert point.
3. Use command DIVIDE to divide the path with the block 'B' in Step 2.
4. Convert the curved polyline into a line-segmented polyline with command FLATTEN.
5. EXPLODE the blocks in Step 3 to extract block 'A'.
6. Use ALTEXT to change the number sequence with 'Along paths' option and select the polyline in Step 5.
Sea-Haven
This is similar to Chainage.lsp place a block at increments along a pline. There is 2 functions that control your answer Vla-getpointatdist and  (vlax-curve-getfirstderiv for the 90 angle. The increment part is very easy just add to a start number and enter attribute.
Will try to do something for you someone else can jump in.
