Lisp to list layer xrefs inserted on
ralstogj
Message 1 of 28
ralstogj
Hi, Guys
I am tying to piece together a piece of lisp code that will look at all the xrefs in a drawing and find what layer they are inserted on and then print the xref name and the layer at the command line. I found this example for listing the paths Example of Listing Paths. It that does something similar to what I want. I have tried for a couple of hours to re write to give the layer name with on luck below is my code so far. If some one could get it working that would be appreciated so long since I did lisp I have forgotten most things.
(defun c:xreflayers ()
(vl-load-com)
(vlax-for item (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))
(if (= (vla-get-isxref item) :vlax-true)
(setq oLayer(vla-item(vla-get-layers(vla-get-activedocument (vlax-get-acad-object)))));; oxref layer
(setq layerName (cdr (assoc 8 (entget oLayer))))
(princ (strcat "\nXref name: "(vla-get-name item)" --- Layer: " layername)
(princ)
Regards
Justin Ralston
http://c3dxtreme.blogspot.com/
Replies (27)
Message 2 of 28
pbejse
@ralstogj wrote:
Hi, Guys
(defun c:xreflayers nil
  (vl-load-com)
  (vlax-for layout (vla-get-layouts
    (vlax-for i	(vla-get-block layout)
      (if (and
	    (eq (vla-get-ObjectName i) "AcDbBlockReference")
	    (vlax-property-available-p i 'Path)
	(princ (strcat "\nXref name: " (vla-get-Name i)
		       " --- Layer: "  (vla-get-Layer i)
  (princ)
Message 3 of 28
braudpat
Hello Mr @pbejse
1) Thanks for our excellent routine : XrefLayersList
2) Please could you give us 4 other variants (for the other XREFs) :
XrefImagesList , XrefPdfsList , XrefDgnsList , XrefDwfsList
Thanks in advance, Regards, Patrice
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 4 of 28
ralstogj
Thanks Patrick work a treat.
Regards
Justin Ralston
Message 5 of 28
pbejse
Nice.
You are welcome.
Message 6 of 28
pbejse
Would you want a prompt to choose the type of XREF underlay or five different commands?
Message 7 of 28
braudpat
Hello @pbejse
Thanks for your effort ! ... Well in fact, I have a dream !
I am ambitious for these routine : SORRY !
1) The routine can be run from the Keyboard and from a Script !
2) Questions: A for ALL types , D for DWG , N for DGN , F for DWF , P for PDF , I for Image
3) Question: C for Current Space (Model or Layout) or A for ALL Spaces (Model + All Layouts)
4) Question: Result on text/command screen (T option) or into a text Tile (F  option)
If F ask for the filename ?
If existing file: Replace or Append
5) Please add the layer name on which is inserted the XREF !
So the result will be a 3 columns text ...
NOW the routine is much more COMPLEX !
Thanks in advance, Regards, Patrice (The French EE Froggy)
Patrice BRAUD
Message 8 of 28
pbejse
Smiley Surprised Now I regretted asking the question, I will work on Patrice, hang in there.
Message 9 of 28
pbejse
Status --->  WIP
command: XREFUnderlay
Choose type [All/Dwg/dGn/dwF/PDF/Image] <All>: ⏎
Layout to process [Current/All] <All>: ⏎
Result on text/command screen [Text/File] <Text>:
This is a sample output on screen
BlockReference ......................................3 Found
XREF SAMPLE 1 ...............................THIS-LAYER-NAME
XREF SAMPLE LONGER NAME ..............THAT-LAYER-LONGER-NAME
XREF SAMPLE EVEN LONGER NAME ................THIS-LAYER-NAME
RasterImage .........................................1 Found
IMAGE SAMPLE 1 ..............................THIS-LAYER-NAME
DwfReference ........................................1 Found
DWF SAMPLE 1 ................................THIS-LAYER-NAME
DgnReference ........................................1 Found
Dgn SAMPLE 1 ................................THIS-LAYER-NAME
PdfReference ........................................1 Found
PDF SAMPLE 1 ................................THIS-LAYER-NAME
Can you please elaborate on this
Message 10 of 28
braudpat
Hello Jedi Master of the Lisp/VLisp
Question: Result on Text/command screen (T) or on a File (F) (Default=T) : ?
If File (F)
Navigate on the Units (C:, D:, etc) and give/find a TXT,CSV File
If a NEW  Filename go on ...
If existing Filename Question: Replace the file (R) or Append at the end (A) (Default=R) : ?
Is it clear ?
Thanks Again, Regards, Patrice
Patrice BRAUD
Message 11 of 28
pbejse
@braudpat wrote:
If File (F)
You specify 3 columns for the external file, the object name, layer name, and what's the third one?
I assumed the file will always be appended when running in the script?
Message 12 of 28
braudpat
Hello
1) YES 3 columns :
object name, layer name and the complete path
2) When running in Script mode:
If the filename exist then Append automatically
If the filename doesn't exit, create a new one ...
Thanks, Regards, Patrice
PS: if an Image or DWG or XXX, is inserted as a XREF N times, of course we will get N lines !
Patrice BRAUD
Message 13 of 28
braudpat
Hello
If it is too complex to do all the job in ONE routine !?
Please 2 routines : one standard and the other one ONLY Script ...
Regards, Patrice
Patrice BRAUD
Message 14 of 28
pbejse
    	"\n::---------------------------------------------------------::"
	"\n::  XREFUnderlay is now loaded [command version <DRAFT>]   ::"
Command: XREFUNDERLAY
Choose type [All/Dwg/dGn/dwF/PDF/Image] <All>: A
Result on text/command screen [Text/File] <Text>: T
Layout to process [Current/All] <All>: A
Result on text/command screen [Text/File] <Text>: F
File already exist:
Choose option [Append/oveWrite] <Append>: W
SAMPLE 1,THIS-LAYER-NAME,C:\USERS\PBEJSE\AUTODESK COMMUNITY\XREF SAMPLE 1.DWG
SAMPLE LONGER NAME,THAT-LAYER-LONGER-NAME,C:\AUTODESK COMMUNITY\OTHER FOLDER\SAMPLE LONGER NAME.DWG
SAMPLE EVEN LONGER NAME,THIS-LAYER-NAME,T:\OTHER DRIVE\SAMPLE EVEN LONGER NAME.DWG
We'll deal with the script enabled version later or perhaps you can figure it out on your own 🙂
HTH
Message 15 of 28
braudpat
Hello
SORRY : small problem !
Commande: XREFUNDERLAY
; erreur: Le serveur ActiveX a renvoyé l'erreur: nom inconnu: "Path"
Commande:
ENTER twice  or  A twice : same result !
Into your code you use "path" HERE :
         ("Dwg"     "AcDbBlockReference"      "Path"        BlockReference    )
If i remove this line, the routine runs BUT I can't get Info from DWG XREF ...
I have added the (vl-load-com) into your LSP ...
Regards, Patrice
PS: Tests done with ACAD MAP 2019 & ACAD MAP 2014 ...
Patrice BRAUD
Message 16 of 28
pbejse
My ßad, i know whats wrong with it.
I'll Modify the code as soon as i get my hands on a computer.
Message 17 of 28
pbejse
 (if (and
(setq f (assoc objectName op)) (setq fname (findfile (vlax-get i (Cadr f))))<-- that being the property "Path"
The error is caused by regular blocks having "AcDbBlockReference"  as objectname value but doesn't have the property 'Path.
We now add the function vlax-property-available-p  to avoid the error.
 (if (and
   (vlax-property-available-p i (Cadr f))
Now back to append, Would you want the code to include the filename before the list is found names etc..?
T:\PROJECT FOLDER\PROJECT NAME\02-DETAIL\PROJECT SHEET NUMBER 1.DWG
T:\PROJECT FOLDER\PROJECT NAME\02-DETAIL\PROJECT SHEET NUMBER 2.DWG
We are getting there.
pBe
Message 18 of 28
braudpat
Hello
If possible in this order :
1) The XREF Name
2) The Layer
3) The Path (if it exists)
Regards, Patrice
Patrice BRAUD
Message 19 of 28
pbejse
Did you try the mod shown on my previous post? It should work now me thinks.
@braudpat wrote:
If possible in this order : ..
It is already in that order, what I'm asking was the order of the data when using the routine in a script to process multiple files.
Say on the first file, the user specifies a filename for the csv file [ PROJECT123.CSV ],  the succeeding files will not prompt the user for a filename and just append the PROJECT123.CSV. If i were to collect the data, I would want the list to show which files the list belongs to.
Now i'm not sure we're on the same page Smiley Happy
Message 20 of 28
braudpat
Hello
Yes the xxxxxx.CSV will collect the Xrefs of all DWGs , so it is an Append ...
But don't forget to include a title line with the main DWG filename which is processed ...
Regards, Patrice
Patrice BRAUD
