Find Text LISP Routine
Hello Guys,
I am quite new to LISP routines. I need help with a LISP Routine that finds text and returns the count of search results in a drawing. The text could be MTEXT or within attribute. It would be great if we can also search multiple words (optional).
pbejse
@Anonymous wrote:
Hello Guys,
In a way, FIND command will do that for you. Show us an example of what you are looking for.
serag.hassouna
Well, You can try this command "textsearch",
It does the following:-
  1. It gets number of occurrences of the supplied text within the drawing.
  2. For every attribute definition it sees if its "value" and/or "tag" match the supplied text.
  3. If there's any block reference, it dives into it and searches for any match cases among its elements.
What the command prompts:
  1. Total no. of text occurrences.
  2. No. of matched attribute definition values.
  3. No of matched attribute definition tags.
serag.hassouna
To search multiple words, you can simply append these words to a list, then use something like that
(setq words (list "w1" "w2" "w3")) ;|the list of words to be searched for,
replace [ (list "w1" "w2" "w3") ] with the appropriate appending routine. |; (setq final_results (mapcar (function (lambda (x) (textsearch_pure x nil (entnext)) );lambda );function words );mapcar );setq
But be notified that there's a downside to just repetitively lean on "textsearch_pure",i.e. if you have for example a drawing with 300 entities, this means that the above-mentioned code will work with effectively 900 entities (in length/execution time), that means, you have to think of making a routine that returns all existing "strings" within the drawing and their respective numbers of occurrences and assign it to a global variable, then simply look for the needed texts within this global variable.
But also know that this downside is really a downside only if the drawings' texts will not be modified or deleted.
__________________
P.S. Any arguments upon the correctness of this replay are "especially "welcomed.
