lisp to link viewport to object in model space and follow it almost finish
dani_cs
dani_cs
Hello all
I found a great lisp. You make a viewport in each layout, then, you write "hvpo_sync" and the code links each viewport to a block in model space. If you move the blocks and then, you write "hvpo_sync" again, all layouts will fit the block again (awesome if you have 30 layouts and have to change the view of 20 or 25).
But there is just a problem. The code only creates block in model space according to the universal UCS. I mean, if you have viewport in other ucs, the code does not create a rotated block. It creates the block in universal UCS
Is it possible to improve the code in order to fill layouts according to their ucs view?
thanks in advance.
cadffm
>>"Is it possible to improve the code in order to fill layouts according to their ucs view?"
Yes, it is possible to edit the code for ROTATION AND SCALE of the "VIEWPORTASSOCIATION_MSOBJECT".
Time to go to your developer or wait for a bored soul.
Sebastian
dani_cs
Hello @cadffm
thanks for your response.
That lisp was uploaded by other user, who found it in other forum. So, I am afraid it will not be possible to find the developer.
thanks again.
cadffm
I found this post, but what I wrote was:
"Time to go to your developer or wait for a bored soul."
Means, Someone who does the job for you.
I wish you much success.
Sebastian
dani_cs
Hello @cadffm
Yes, you found this post and you wrote something and I just thanked you for that
Means, I thank people who spent 30 seconds to write a post, nothing else.
