Lisp to insert multiple blocks in different positions
PdroLCS
PdroLCS
I have several .dwg files and I want to insert them as blocks into a single file in different positions... XREF doesn't work in this case because I need to insert them simultaneosly, but they cannot be in the same position, overlapping.
I think it could be solved with a LISP routine but I'm not sure.
pendean
Community Legend
Community Legend
What would determine the exact coordinates for "different positions" so the LISP can function autonomously?
Or do you just need to use -INSERT command on repeat (MULTIPLE command does that) if those locations are not exact?
Or do you just need to CTRL+SHIFT+C one time then CTRL+SHIFT+V one time then COPY as many times as you need right now on your keyboard?
Kent1Cooper
See my BlockChart routines >here<.  They are made to Insert all files in a chosen directory so that they don't overlap.  So if you put your drawings into a folder together, it's all set to go.  Read the comments in the file and the linked topic.
I don't see why the same couldn't be done with XREF instead of INSERT, if you'd rather have them as Xrefs in the end.
Kent Cooper, AIA
