Hi @Sea-Haven
Thanks for sharing this - it seems close to the solution I need!
When I run this, as (upurl), with the spreadsheet open and active, it opens a blank instance of an Excel file, and asks me for a row number. I type 8 - that's the last row in my test spreadsheet.
I then get a "bad argument type: VLA-OBJECT nil" error.
I added (vl-load-com) at the beginning of the code, but not sure why it's opening another instance of Excel. Also, I found a typo- in the variable list for "bname" (it was spelled "banme").
Here is what I'm working with now:
(defun upurl ( / getcell2 myXL row rowmax x k ss ss2 bname ent obj atts att1 att2)
(vl-load-com)
;; Thanks to fixo ;;
(defun getcell2 (row column / )
(setq cells (vlax-get-property (vlax-get-property myXL "ActiveSheet") "Cells"))
(setq cell (vlax-get (vlax-variant-value (vlax-get-property cells "Item" row column)) 'value))
(or (setq myXL (vlax-get-object "Excel.Application"))
(setq myXL (vlax-get-or-create-object "excel.Application"))
(vla-put-visible myXL :vlax-true)
(vlax-put-property myXL 'ScreenUpdating :vlax-true)
(vlax-put-property myXL 'DisplayAlerts :vlax-true)
(setq row 2)
(setq rowmax (- (getint "\nEnter last row number ") 1))
(setq lst '())
(repeat rowmax
(setq c1 (getcell2 row 1)
c2 (getcell2 row 2)
c3 (getcell2 row 3)
(setq lst (cons (list c1 c2 c3) lst))
(setq row (1+ row))
(setq ss (ssget (list (cons 0 "INSERT")(cons 2 "**U*"))))
(if (= ss nil)(progn (Alert "you have not selected any DetailBubble blocks will exit ")(exit)))
(setq ss2 (ssadd))
(repeat (setq k (sslength ss))
(setq ent (ssname ss (setq k (1- k))))
(setq bname (vlax-get (vlax-ename->vla-object ent) 'effectivename))
(if (= bname "DetailBubble")
(setq ss2 (ssadd ent ss2))
(repeat (setq k (sslength ss2))
(setq obj (vlax-ename->vla-object (ssname ss2 (setq k (1- k)))))
(setq atts (vlax-invoke obj 'Getattributes))
(setq att1 (vlax-get (car atts) 'textstring))
(setq att2 (vlax-get (cadr atts) 'textstring))
(setq hyper_link (vla-item (vla-get-hyperlinks obj) 0))
(repeat (setq x (length lst))
(setq hyp (nth (setq x (1- x)) lst))
(setq hyp1 (car hyp) hyp2 (cadr hyp) hyp3 (caddr hyp) )
(if (and (= hyp1 att1)(= hyp2 att2))
(progn
(vla-put-url hyper_link hyp3)
(vla-put-urldescription hyper_link hyp3)
(princ)
But I'm still getting the error "bad argument type: VLA-OBJECT nil".
In VLIDE, I ran a "Check Selection" - and this is the return (not sure what I'm doing wrong):
[CHECKING TEXT <Untitled-0> loading... SELECTION]
; warning: local variable used as function: GETCELL2
; Check done.
