OKAY sir thanks for your effort
I got this lisp code it make a field text Variable according to any changes of shape but it get area only without perimeter and unit of it is feet and also size of text is small according to my scale
;;; AreaText.LSP ver 4.0
;;; Command names are AT, ATC, ATM
;;; AT command: Select a polyline and where to place the text
;;; ATC command: Select a polyline and add the text at the geo center of the selected object
;;; ATM command: Select multiple objects and add the text at the boundary box center
;;; Sample result: 2888.89 SQ. FT.
;;; As this is a FIELD it is updated based on the FIELDEVAL
;;; or the settings found in the OPTIONS dialog box
;;; By Jimmy Bergmark
;;; Copyright (C) 2007-2018 JTB World, All Rights Reserved
;;; Website:
https://jtbworld.com;;; E-mail: info@jtbworld.com
;;; 2007-09-05 - First release
;;; 2009-08-02 - Updated to work in both modelspace and paperspace
;;; 2010-10-29 - Updated to work also on 64-bit AutoCAD
;;; 2018-11-11 - Added command ATC to add the text at the geo center on selected object
;;; Added command ATM to add the text at the bounding box center on selected objects
;;; Uses TEXTSIZE for the text height
;;; rows starting with one or more semicolons are comments
;;; for the area in square feet leave the below row uncommented or modify as needed
(setq jtbfieldformula ">%).Area \\f \"%pr2%lu2%ct4%qf1 SQ. FT.\">%")
;;; for the area in square meters leave the below row uncommented or modify as needed
;(setq jtbfieldformula ">%).Area \\f \"%lu2%pr1%ps[,m²]%ct8[0.001]\">%")
(defun Get-ObjectIDx64 (obj / util)
(setq util (vla-get-Utility
(vla-get-activedocument (vlax-get-acad-object))
(if (= (type obj) 'ENAME)
(setq obj (vlax-ename->vla-object obj))
(if (= (type obj) 'VLA-OBJECT)
(if (> (vl-string-search "x64" (getvar "platform")) 0)
(vlax-invoke-method
util
"GetObjectIdString"
obj
:vlax-False
(rtos (vla-get-objectid obj) 2 0)
;;; Select a polyline and where to place the text
(defun c:AT (/ entObject entObjectID InsertionPoint ad)
(vl-load-com)
(setq entObject (vlax-ename->vla-object (car (entsel)))
entObjectID (Get-ObjectIDx64 entObject)
InsertionPoint (vlax-3D-Point (getpoint "Select point: "))
ad (vla-get-ActiveDocument (vlax-get-acad-object))
(vla-addMText
(if (= 1 (vla-get-activespace ad))
(vla-get-modelspace ad)
(if (= (vla-get-mspace ad) :vlax-true)
(vla-get-paperspace ad)
InsertionPoint
0.0
(strcat
"%<\\AcObjProp Object(%<\\_ObjId "
entObjectID
jtbfieldformula
;;; Select a polyline and add the text at the geo center of the selected object
(defun c:ATC (/ ent entObject entObjectID InsertionPoint ad mtextobj)
(vl-load-com)
(setq entObject (vlax-ename->vla-object (car (setq ent (entsel))))
(trans (osnap (cadr ent) "_gcen") 1 0)
(setq mtextobj
(vla-addMText
InsertionPoint
0.0
(strcat
entObjectID
jtbfieldformula
(vla-put-AttachmentPoint mtextobj 5)
(vla-put-insertionPoint mtextobj InsertionPoint)
;;; Select multiple objects and add the text at the boundary box center
(defun c:ATM (/ ss1 nr tot_area
ad mtextobj minExt maxExt
(vl-load-com)
(if (setq ss1 (ssget '((-4 . "<OR")
(0 . "POLYLINE")
(0 . "LWPOLYLINE")
(0 . "CIRCLE")
(0 . "ELLIPSE")
(0 . "SPLINE")
(0 . "REGION")
(-4 . "OR>")
(progn
(setq nr 0)
(setq tot_area 0.0)
(setq en (ssname ss1 nr))
(while en
(setq entObject (vlax-ename->vla-object en)
(vla-GetBoundingBox entObject 'minExt 'maxExt)
(setq minExt (vlax-safearray->list minExt)
maxExt (vlax-safearray->list maxExt)
(setq
InsertionPoint
(vlax-3D-Point
(list
(/ (+ (car minExt) (car maxExt)) 2)
(/ (+ (cadr minExt) (cadr maxExt)) 2)
(/ (+ (caddr minExt) (caddr maxExt)) 2)
(setq mtextobj
(vla-addMText
InsertionPoint
0.0
(strcat
entObjectID
jtbfieldformula
(command "._area" "_O" en)
(setq tot_area (+ tot_area (getvar "area")))
(setq nr (1+ nr))
(princ "\nTotal Area = ")
(princ tot_area)
(setq ss1 nil)
(princ)
(princ)
