lisp to delete zero attributes
DOODLEANU
Message 1 of 10
DOODLEANU
hi ,
Can anyone please help me to give a lisp;
check all attributes values of few block selection, if there is any att value zero, make all of them empty.
Accepted solutions (3)
Replies (9)
Message 2 of 10
komondormrex
hey,
do you mean by 'value zero' "0" value or "" value?
if "0" value
(defun c:empty_atts_if_zero (/ insert_sset all_atts_list )
  (if (setq insert_sset (ssget '((0 . "insert") (66 . 1))))
    	(mapcar '(lambda (attribute) (if (= "0" (vla-get-textstring attribute)) (vla-put-textstring attribute "")))
		  (setq all_atts_list (apply 'append (mapcar '(lambda (insert) (vlax-invoke insert 'getattributes))
						   	      (mapcar 'vlax-ename->vla-object
								      (vl-remove-if 'listp
										    (mapcar 'cadr (ssnamex insert_sset))
  (princ)
updated
Message 3 of 10
Moshe-A
@DOODLEANU  hi,
check this EMPTYATT command
enjoy
moshe
(defun c:emptyatt (/ ss ent AcDbBlkRef AcDbAttrib)
 (if (setq ss (ssget '((0 . "insert") (66 . 1))))
  (foreach ent (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
   (setq AcDbBlkRef (vlax-ename->vla-object ent))
   (foreach AcDbAttrib (vlax-invoke AcDbBlkRef 'GetAttributes)
    (if (eq (vla-get-textString AcDbAttrib) "0")
     (vla-put-textString AcDbAttrib "")
    (vlax-release-object AcDbAttrib)
   (vlax-release-object AcDbBlkRef)
  ); foreach
 ); if
 (princ)
Message 4 of 10
DOODLEANU
I wanna make 0 to """
Message 5 of 10
DOODLEANU
its works perfect for me thank you
Message 6 of 10
DOODLEANU
Thank you
Message 7 of 10
DOODLEANU
@Moshe-A @komondormrex
how about  all blocks with a specific name lets say
block name example Block1
instead of selecting them
Message 8 of 10
komondormrex
and 'Block1' is static or dynamic?
Message 9 of 10
DOODLEANU
Dynamic block.
Message 10 of 10
komondormrex
check the following
  (if (setq insert_sset (ssget "_x" '((0 . "insert") (66 . 1))))
								  (vl-remove-if-not '(lambda (insert) (member (strcat (vla-get-effectivename insert))
								  											  (mapcar 'strcat '("block1")))
  (princ)
