Lisp to delete a code specified layer Frozen or Not
timothy_crouse
timothy_crouse
Hello
Does anyone have a lisp that will delete a hard coded layer regardless of the layer state,
ON, OFF, FROZEN.
I guess it should set the current layer to layer 0 first
Delete the layer by name
Purge the drawing
I am looking for a lisp that works like this so I can include in a Hurrican Script.
Thanks in Advance
-Tim C.
Kent1Cooper
(command
  "_.layer" "_unlock" "YourLayerName" "_set" "0" ""
  "_.laydel" "_name" "YourLayerName" "" "_yes"
No need to Purge afterwards [for the Layer, at least] -- LAYDEL takes care of that.
EDITED:  It doesn't matter whether the Layer is off or frozen, but it won't do it if it's locked, so I added unlocking it first, along with setting 0 current just in case as you said.
Kent Cooper, AIA
timothy_crouse
Thank You for your help
