LISP to create lines between basepoints of multiple selected objects
mbk.ee11
mbk.ee11
Is there any existing lisp routine or a method to create/place lines between basepoints of multiple selected objects? See attached drawing for what exactly I'm looking for. Any help, much appreciated. Thanks in advance!!!
Kent1Cooper
Put something like "connect blocks" in the Search window -- there is probably something among the findings that will do what you want.
Kent Cooper, AIA
Moshe-A
@mbk.ee11  hi,
check PCHAIN command.
the best suit for selection is WP (window polygon)
enjoy
Moshe
(vl-load-com)
(defun c:pchain (/ get_points _sortby draw_pline ; local functions
		  ss points^ xdir^ ydir^)
 (defun get_points ()
  (mapcar
    (function
      (lambda (ename)
       (cdr (assoc '10 (entget ename)))
      ); lambda
    ); function
   (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
  ); mapcar
 ); get_points
 (setq _sortby (lambda (f l) (vl-sort l (function (lambda (e0 e1) (< (f e0) (f e1)))))))
 (defun draw_pline (lst / pt)
  (command "._line")
  (foreach pt lst
   (command "_none" pt)
  (command "")
 ); draw_pline
 ; here start c:pchain
 (setvar "cmdecho" 0)
 (command "._undo" "_begin")
 (if (setq ss (ssget '((0 . "insert"))))
  (progn
   (setq points^ (get_points))
   (setq xdir^ (_sortby car  points^))
   (setq ydir^ (_sortby cadr points^))
   (if (> (distance (car xdir^) (car (reverse xdir^))) (distance (car ydir^) (car (reverse ydir^))))
    (draw_pline xdir^)
    (draw_pline ydir^)
   ); if
  ); progn
 ); if
 (command "_undo" "_end")
 (setvar "cmdecho" 1)
 (princ)
); c:pchain
mbk.ee11
Thank you so much @Moshe-A . It works very well.
