Lisp to create continuous line - helpp
Im in trouble with this lisp.
1. draw line, as many segments as the user wants;
2. to stop the line drawing, hit enter (the normal commmand it already happen);
3. prompt something, like "line has been created.";
Iam new at programming lsp, so any help is greatly appreciated.
cadffm
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/polyline-pick-and-user-input/m-p/909...
(command "_.line")
(while (eq 1 (getvar "cmdactive"))
(prompt "\nPick point: ")
(command pause)
Sebastian
Kent1Cooper
A refinement....
It doesn't need to prompt for the next point -- the Line command will take care of that for you.  Letting it do so preserves the visibility in the prompt of the Undo and [after at least two segments] Close options.
And the CMDACTIVE System Variable has various values, so you don't need to check for its being 1 specifically, but anything greater than zero.
(command "_.line")
(while (> (getvar 'cmdactive) 0) (command pause))
(prompt "\nLine has been created.")
(princ)
Kent Cooper, AIA
Thank you guys !
I didn't knew the "cmdactive". It will be very helpfull in my future codes.
ВeekeeCZ
@Anonymous wrote:
..I didn't knew the "cmdactive". It will be very helpfull in my future codes.
Guess what, you don't even need that.
(command-s "_.line")
Kent1Cooper
I keep forgetting about that, because the description of the (command-s) function sounds  as though it shouldn't work that way -- particularly this:
"Token streams fed in a single command-s expression must represent a full command and its input."
But in fact it does work as suggested.  I think Autodesk needs to revise the description [or change the way it works to agree with the description].
Also, (command-s) is not present in older versions [pre-2014 or something like that?].
Kent Cooper, AIA
