LISP to create a line and text from a layer name
Message 1 of 29
I am new to LISP and was wondering if it is possible to draw a line and then another below that (such as an array) one each for all the layers in a drawing? I would also like to create text next to the line that has the name of the layer. This line and text should be on the layer in question.
I can do it manually but wondered if was easier to automate!
Many thanks for your time
Adam
Replies (28)
Message 21 of 29
pbejse
This in blue
        (progn (acad_strlsort (mapcar '(lambda (x) (and (null (member x lst)) (setq lst (cons x lst))))
                                      (mapcar '(lambda (x) (cdr (assoc 8 (entget x))))
                                              (vl-remove-if 'listp (mapcar 'cadr (ssnamex (ssget)))))))
               lst)
to this in red
(progn (mapcar '(lambda (x) (and (null (member x lst)) (setq lst (cons x lst))))
       (acad_strlsort lst))
Message 22 of 29
tranminhthong0993
Bother you too but has not yet run ☹️
Message 23 of 29
chrisb6F6PK
Thanks all for the routines.  I did some modifications...
Filter out xref layers, added a description to the layer name.
(defun c:test ( / doc lyrs lst pt both)
  (setq doc (vla-get-activedocument (vlax-get-acad-object))
        lyrs (vla-get-layers doc)
  );end_setq
  (vlax-for lyr lyrs (setq lst (cons (vlax-get lyr 'name) lst)))
  (setq lst (vl-sort lst '< )
        pt (getpoint "\nSelect insertion point: ")
  );end_setq
  (foreach lyr lst
(if (not (wcmatch lyr "*|*"))
(progn
(if (zerop (strlen (setq desln (getpropertyvalue (tblobjname "layer" lyr) "Description"))))(setq both lyr)(setq both (strcat lyr " (Description) " (getpropertyvalue (tblobjname "layer" lyr) "Description"))))
    (entmakex (list '(0 . "line") (cons 10 pt) (cons 11 (mapcar '+ pt '(2.5 0 0))) (cons 8 lyr)))
    (entmakex (list '(0 . "text") (cons 10 (mapcar '+ pt '(3.0 0 0))) '(40 . 0.1) (cons 1 both) (cons 8 lyr)(cons 7 "RE Text")))
    (setq pt (mapcar '- pt '(0 0.15 0)))
));end_if_pron
  );end_foreach
  (princ)
Message 24 of 29
tdeleske
Hi chrisb6F6PK, I am trying this routine is almost what I am looking for, however, instead of the Layer description, how can I change it to show me the Layer Linetype names in the text output?
Message 25 of 29
Kent1Cooper
@tdeleske wrote:
.... instead of the Layer description, how can I change it to show me the Layer Linetype names in the text output?
Try [untested] replacing this part:
with this:
(setq both (strcat lyr " (Linetype) " (cdr (assoc 6 (entget (tblobjname "layer" lyr))))))
Kent Cooper, AIA
Message 26 of 29
tdeleske
Thank you Kent! it worked perfect! much apricated.
Regards
Trevor
Message 27 of 29
JGAo1
Thanks for this lisp, it works perfectly.
JGA
Message 28 of 29
jzweygardt
This is very helpful. Thanks a bunch!
Message 29 of 29
ccarva2
Try this:
(defun c:somefunc (/ pt dat ln layerlist sortedlayerlist)
(setq pt (getpoint "\nSelect insertion point: "))
(setq layerlist '())
(while (setq dat (tblnext "layer" (null dat)))
(setq layerlist (cons (cdr (assoc 2 dat)) layerlist))
(setq sortedlayerlist (acad_strlsort layerlist))
(foreach ln sortedlayerlist
(entmake (list '(0 . "line") (cons 10 pt) (cons 11 (mapcar '+ pt '(2.5 0 0))) (cons 8 ln)))
(entmake (list '(0 . "text") (cons 10 (mapcar '+ pt '(3.0 0 0))) '(40 . 0.1) (cons 1 ln) (cons 8 ln)))
(princ)
