Have ALL dim styles change to 1 layer
3arizona
3arizona
I found this lisp on one of the forums.
I have modified to my standards. Is there a way for all dims to update to the current style? the way its set up now, you have to give it a style.
if it can't be done is there a way to remove the dimension update? all i'm looking for is to place all dimensions to layer 35 color 10.
 here is the lisp:
(defun c:TESTdims (/ *error* ocm lays ss)
(defun *error* (msg)
(if ocm (setvar "CMDECHO" ocm))
(if (not (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*"))
(princ (strcat "\n<< Error: " msg " >>")))
(princ))
(setq ocm (getvar "CMDECHO")
lays (vla-get-layers
(vla-get-ActiveDocument
(vlax-get-acad-object))))
(setvar "CMDECHO" 0)
(or (tblsearch "LAYER" "35")
(vla-put-color
(vla-add lays "35") 10))
(if (and (tblsearch "DIMSTYLE" "Standard")
(setq ss (ssget "_X" '((0 . "LEADER,DIMENSION")))))
(progn
(command "-dimstyle" "_R" "standard")
(command "_.chprop" ss "" "_LA" "35" "")
(command "-dimstyle" "_A" ss ""))
(princ "\n<< No Dimensions Found, or Dimstyle Doesn't Exist >>"))
(princ))
DannyNL
Use the variable DIMSTYLE to determine the current dimension style.
And as you are using the current dimension style there is no need to check if it exists anymore.
(non-tested)
   (if
      (progn
         (command "-dimstyle" "_R" (getvar "DIMSTYLE"))
3arizona
DannyNL,
this works!!
thanks, for your time.
DannyNL
You're welcome Smiley Happy
