Lisp to Copy Mtext but paste only the first line
tiwari1211
Message 1 of 51
tiwari1211
Dear Lisp experts.  I hope you all are doing well.
Do we have any Lisp to copy only the first line of MTEXT. I have many drawings where i need to copy only the first line to other position. presently i use copy command and then manually delete the remaining bottom lines. I dont want to explode the MTEXT.
Can anyone help me in this. Thank you very much
Replies (50)
Message 42 of 51
tiwari1211
Hi, This is also me looking for solution.
Message 43 of 51
ВeekeeCZ
Post the source dwg to it.
BTW posting the same request to multiple forums is the reason for some to ignore it. Me included.
Message 44 of 51
tiwari1211
@ВeekeeCZ @Sea-Haven
I had no idea, I was looking for the help but I will take care of this in future. Many thanks for your suggestion.
DXF file is attached now.
Message 45 of 51
Sea-Haven
If you want to stay in excel and get results in excel and a table, start googling "VBA make table Autocad"
Message 46 of 51
tiwari1211
I want this table in Autocad not in excel. Thanks
Message 47 of 51
ВeekeeCZ
(vl-load-com)
(defun c:TableFromE-text ( / LM:str->lst insert_table acdoc s p i a c l)
  ;; String to List  -  Lee Mac
  ;; Separates a string using a given delimiter
  ;; str - [str] String to process
  ;; del - [str] Delimiter by which to separate the string
  ;; Returns: [lst] List of strings
  (defun LM:str->lst ( str del / pos )
    (if (setq pos (vl-string-search del str))
      (cons (substr str 1 pos) (LM:str->lst (substr str (+ pos 1 (strlen del))) del))
      (list str)))
  (setq acdoc (vla-get-activedocument (vlax-get-acad-object)))
  ; not mine, thx anyone who wrote it.
  (defun insert_table (lst title header pct / tab row col ht i n space)
    (setq space (vlax-get acDoc (if (= 1 (getvar 'cvport)) 'PaperSpace 'ModelSpace))
	  ht  (/ 150 (cond ((getvar 'cannoscalevalue)) (1.0)))
	  pct (trans pct 1 0)
	  n   (trans '(1 0 0) 1 0 T)
	  tab (setq tab (vla-addtable space (vlax-3d-point pct) (+ (if title 1 0) (if header 1 0) (length lst)) (length (car lst)) (* 150 ht) ht)))
    (vlax-put tab 'direction n)
    (mapcar '(lambda (rowType)
	       (vla-SetTextStyle  tab rowType (getvar 'textstyle))
	       (vla-SetTextHeight tab rowType ht))
	    '(2 4 1))
    (vla-put-HorzCellMargin tab (* 0.2 ht))
    (vla-put-VertCellMargin tab (* 0.2 ht))
    (if header (setq lst (cons header lst)))
    (setq i 0)
    (foreach col (apply 'mapcar (cons 'list lst))
      (vla-SetColumnWidth tab i
	(apply 'max (mapcar '(lambda (x)
			       ((lambda (txb) (+ (abs (- (caadr txb) (caar txb))) (* 2.2 ht)))
				 (textbox (list (cons 1 (vl-princ-to-string x)) (cons 7 (getvar 'textstyle)) (cons 40 ht)))))
			    col)))
      (setq i (1+ i)))
    (setq lst (cons (list title) lst))
    (setq row 0)
    (foreach r lst
      (setq col 0)
      (vla-SetRowHeight tab row (* 2 ht))
      (foreach c r
	(vla-SetText tab row col (if (numberp c) (rtos c) (vl-princ-to-string c)))
	(setq col (1+ col)))
      (setq row (1+ row))))
  (if (and (setq s (ssget "_X" '((0 . "MTEXT") (8 . "E-text"))))
	   (setq p (getpoint "\nTable scale depend on annotation scale.\nSpecify table insert point: "))
    (repeat (setq i (sslength s))
      (if (setq c (cdr (assoc 1 (entget (ssname s (setq i (1- i))))))
		c (list (substr c 1 (vl-string-search "/" c))
			(substr c (setq z (+ 2 (vl-string-search "/" c))) (- (vl-string-position (ascii "-") c nil T) z -1))
			(atoi (substr c (+ 2 (vl-string-position (ascii "-") c nil T))))))
	(setq l (if (setq a (assoc (car c) l))
		  (subst (reverse (cons (+ (last c) (last a)) (cdr (reverse a)))) a l)
		  (cons c l))))
  (and l
       (setq l (vl-sort l '(lambda (e1 e2) (< (car e1) (car e2)))))
       (setq i 0)
       (setq l (mapcar '(lambda (x) (list (itoa (setq i (1+ i))) (car x) (cadr x) (itoa (last x)))) l))
       (insert_table l "Export" '("SNo" "Item No" "Material" "Qty") p)
  (princ)
Message 48 of 51
tiwari1211
It works perfectly as required. Many many thanks for your help.
Message 49 of 51
tiwari1211
Hi, Can you please guide me books to learn the Lisp basics ?
Also how can i add 3 more columns in the table for (bending, welding & Final check).
I tried and added this in the last line of your program but it didn't worked.
Message 50 of 51
ВeekeeCZ
THIS site is generally recommended as a good starting point.
Possibly like this.
(vl-load-com)
      (list str)))
	  pct (trans pct 1 0)
	    '(2 4 1))
    (setq i 0)
			    col)))
      (setq i (1+ i)))
    (setq row 0)
    (foreach r lst
      (setq col 0)
      (foreach c r
		  (cons c l))))
  (and l
       (setq i 0)
       (setq l (mapcar '(lambda (x) (list (itoa (setq i (1+ i))) (car x) (cadr x) (itoa (last x)) "-" "-" "-")) l))
       (insert_table l "Export" '("SNo" "Item No" "Material" "Qty" "bending" "welding" "Final check") p)
  (princ)
Message 51 of 51
tiwari1211
Hi, This works very well on Autocad. Any idea why it does not work on DraftSight ?
