Lisp to Copy Mtext but paste only the first line
tiwari1211
Message 1 of 51
tiwari1211
Dear Lisp experts.  I hope you all are doing well.
Do we have any Lisp to copy only the first line of MTEXT. I have many drawings where i need to copy only the first line to other position. presently i use copy command and then manually delete the remaining bottom lines. I dont want to explode the MTEXT.
Can anyone help me in this. Thank you very much
Replies (50)
Message 2 of 51
Kent1Cooper
Are the "remaining bottom lines" separate lines as a result of Enter(s) being used to move down to a next line?  If so, I can imagine a way to do what you want.  Or are they subsequent lines because of word wrapping resulting from the width of the defining box?  If so, I'm not sure how one would approach the problem, but there may be a way.
Kent Cooper, AIA
Message 3 of 51
tiwari1211
Hello Kent,
Thank you for your reply.
Yes, the remaining bottom lines are result of Enter(s). So what i need is to copy only the first line.
Also before doing paste if i have option to enter the text height. this will be great.
Thank you for helping.
Message 4 of 51
Kent1Cooper
@tiwari1211 wrote:
....Yes, the remaining bottom lines are result of Enter(s). So what i need is to copy only the first line.
Also before doing paste if i have option to enter the text height. this will be great. ....
Here's a fairly quickie approach, lightly tested:
;| CopyMTextLine1.lsp [command name: CMTL1]
To Copy Mtext only up to the first Enter [if any] encountered, with
  specification of [new] height, offering current height as default.
Creates new Mtext with [if containing Enter(s)] truncated content,
  on same Layer, with same justification, etc., and leaves User in
  Move command to specify new location.
If Mtext contains no Enter(s), simply Copies it [with new height if
  specified].
NOTE:  Width of defining Mtext box is NOT changed, so if height
  is increased, word wrapping can occur in result, or if original had
  new lines from word wrapping before Enter(s), word wrapping
  can change.
Kent Cooper, 9 March 2021
(defun C:CMTL1 ; = Copy MText Line 1 only
  (/ mt mtdata mtht ht txt hard soft newtxt)
  (if
    (and
      (setq mt (car (entsel "\nMText object to Copy 1st line of: ")))
      (member '(0 . "MTEXT") (setq mtdata (entget mt)))
    ); and
    (progn ; then
      (initget 6); no zero, no negative
      (setq ht
        (cond
          ( (getdist ; nil on Enter
              (strcat
                "\nText height <"
                (rtos (setq mtht (cdr (assoc 40 mtdata)))); current height default
              ); strcat
            ); getdist
          ); User-input condition
          (mtht); User Enter -- keep current height
        ); cond
      ); setq
      (if (wcmatch (setq txt (cdr (assoc 1 mtdata))) "*\\P*,*\n*"); contains Enter(s)
        (setq ; then
          hard (vl-string-search "\\P" txt) ; first "hard" Enter if any
          soft (vl-string-search "\n" txt) ; first "soft" Enter [Shift+Enter] if any
          newtxt (substr txt 1 (apply 'min (vl-remove nil (list hard soft))))
            ; from beginning to first type of Enter encountered
        ); setq
        (setq newtxt txt); no Enter(s) -- keep
      ); if
      (entmake
        (append
          (subst (cons 1 newtxt) (assoc 1 mtdata) mtdata); new content
          (list (cons 40 ht)); new height
        ); append
      ); entmake
      (command "_.move" (entlast) "" "_none" (cdr (assoc 10 mtdata)))
    ); progn
  ); if
); defun
Note the NOTE.  If it's important to have the remaining first line "look" the same even at a different size, i.e. to also adjust the Mtext defining box width, it could be altered to use a SCALE command, rather than assigning the new height in entity data.
The height is about that of the "outer" Mtext object.  Anything like a height override inside the Mtext will remain, though since that is assigned proportionally in the text-string formatting, not as an absolute height, the proportion will remain relative to the new height.
Note also that if there is word wrapping from the width of the MText defining box before an Enter is encountered, all content up to the Enter will remain even though wrapped to more than one line.
Kent Cooper, AIA
Message 5 of 51
Moshe-A
@tiwari1211  hi,
here, try this command. if it does not work then send a dwg with your mtext so i will check and fix.
enjoy
Moshe
; copy mtext first line
(defun c:cmt1 (/ ss l ename tarPt AcDbMtext p oText nText)
 (vla-startUndoMark (vla-get-activedocument (vlax-get-acad-object)))
 (if (setq ss (ssget '((0 . "mtext"))))
  (progn
   (repeat (setq l (sslength ss))
    (setq ename (ssname ss (setq l (1- l))))
    (redraw ename 3)
    (if (and
          (setq tarPt (getpoint
                        (cdr (assoc '10 (entget ename)))
                        "\nCopy first text line to:  "
                      ); getpoint
          ); setq
          (setq AcDbMtext (vla-copy (vlax-ename->vla-object ename)))
          (setq p (vl-string-search "\\P" (setq oText (vla-get-textString AcDbMtext))))
     (progn
      (setq nText (substr oText 1 p))
      (vla-put-textString AcDbMtext nText) ; update text
      (vla-move AcDbMtext
                  (vlax-3d-point
                    (trans
                      (vlax-safearray->list
                        (vlax-variant-value
                          (vla-get-insertionPoint AcDbMtext)
                      ) 0 1); trans
                  ); vlax-3d-point
                  (vlax-3d-point tarPt)
      ); vla-move
     ); progn
    ); if
    (redraw ename 4)
   ); repeat
  ); progn
 ); if
 (vla-endundoMark (vla-get-activedocument (vlax-get-acad-object)))
 (princ)
Message 6 of 51
john.uhden
Pretty good, Moshe, but Kent covered the soft returns also (he's learning quite well).  😁
John F. Uhden
Message 7 of 51
Kent1Cooper
I thought you'd appreciate that.   [And the height request.]
Kent Cooper, AIA
Message 8 of 51
john.uhden
I thought I gave you a "like", didn't I? You deserve more of them.
John F. Uhden
Message 9 of 51
Moshe-A
@john.uhden ,
thank you for that 😀 although mine accept selection of multi mtext i still consider YOU and @Kent1Cooper  (and many others) as MASTERS here. with all my many years of experience in AutoCAD\AutoLISP\ActiveX i still learning here new tricks every day so thank you all for your contribution to this Fourm without you this place would not be so attracting and interesting.
keep up the good work\coding.
Moshe
Message 10 of 51
tiwari1211
Thank you very much Kent for your support. The Lisp is very good and works exactly as i want.
Thanks a lot again. 🙂
Message 11 of 51
tiwari1211
Thank you very much Moshe. You too a very good programmer and your code also works. thank you 🙂
Message 12 of 51
tiwari1211
Hi Kent,
What to change in your code, if i want to keep Text height 10 as default ?
In that case i do not need the Text height option too.
Can you please help me with this too. Thank you
Message 13 of 51
Kent1Cooper
@tiwari1211 wrote:
.... What to change in your code, if i want to keep Text height 10 as default ?
In that case i do not need the Text height option too. ....
If you want the new Mtext always at a height of 10 units, regardless of the source Mtext's height, and without asking the User, this should do [minimally tested]:
;| CopyMTextLine1-ht10.lsp [command name: CMTL1]
  height of 10 units regardless of current height.
  not originally 10 units].
NOTE:  Width of defining Mtext box is NOT changed, so word
  wrapping can occur in result if height is increased, or if original had
  new lines from word wrapping before first Enter, word wrapping
  can change.
Kent Cooper, 10 March 2021
  (/ mt mtdata txt hard soft newtxt)
  (if
    (and
    ); and
    (progn ; then
        (setq ; then
        ); setq
      ); if
      (entmake
        (append
          (subst (cons 1 newtxt) (assoc 1 mtdata) mtdata); truncated text
          '((40 . 10.0)); fixed height
        ); append
      ); entmake
    ); progn
  ); if
); defun
It could also be made to always offer 10 units as the default, but still allow the User to call for something else if they want, or to keep the source Mtext's height.
Kent Cooper, AIA
Message 14 of 51
tiwari1211
Thank you very much Kent. Your codes are wonderful. I have one more request.
I extract this MTEXT to an excel file at the end. and did not realized that its depended on Layer.  Now My excel shows both the texts. to avoid it i need the new text with height 10 in Layer "0".  will it be possible.
I am very sorry, i didnt realised this earlier. But at last my final output is not correct. I appreciate your help. thanks
Message 15 of 51
john.uhden
I think your opinion of me is overrated. But you are kind.
John F. Uhden
Message 16 of 51
Kent1Cooper
@tiwari1211 wrote:
... i need the new text with height 10 in Layer "0".  will it be possible.  ....
Change this line:
to this:
'((8 . "0") (40 . 10.0)); Layer 0 & fixed height
Kent Cooper, AIA
Message 17 of 51
Kent1Cooper
A followup question:
Do these ever have a lot of content, like a heading followed by an Enter [or two] and a long paragraph of text, where you want to Copy only the heading?  A content entry can hold only up to 250 characters, so if it's longer than that, the text content will start in an (assoc 3) entry in entity data, and maybe more of those if needed, with the (assoc 1) entry [never more than one of those] being the last content container, holding only the end of the overall content, beyond some multiple of 250 characters.  So in my example situation, if you want to take only the heading, that will need to be pulled from the first (assoc 3) entry [when there are any], not from the (assoc 1) entry.  And the revised entity data would need to have any (assoc 3) entries removed, leaving only the (assoc 1) entry with the truncated content in it.
Is that a possible situation that should be accounted for, in the kinds of things you would use this on?
Kent Cooper, AIA
Message 18 of 51
tiwari1211
Thanks again. 🙏🏻
In my case content will not be more than 100 characters. I wish you a nice day ahead.
Message 19 of 51
pbejse
Also works on altered width: [ no "\\P" found on string ]
;;;		Lee Mac | 11-25-2013		;;;
(defun mattrib-number-of-lines (ent / box enx)
    (setq enx (entget ent)
	  box (textbox (list '(1 . "A") (assoc 7 enx) (assoc 40 enx)))
    (1+ (fix (/ (cdr (assoc 43 enx)) (* 1.66 (- (cadadr box) (cadar box))))))
(defun c:tfs ( / ent no1 remain  obj pos str tmp )
;;	pBe | Mar 2021	hmsilva | 11-24-2013		;;
    (if (setq ent (car (entsel "\nMText object to Copy 1st line of: ")))
      (progn
            (setq  no1 (mattrib-number-of-lines ent)
	  (setq remain (vlax-invoke (vlax-ename->vla-object ent) 'Copy ))
	  (while (> no1 1)
	      (setq str (vla-get-textstring remain) pos 0 )
			    (while (setq tmp (vl-string-search "\\P" str pos))
	                            (setq pos (+ tmp 2))
	    (vla-put-textstring
	      remain (substr str
		      1 (max (- pos 2)
			   (cond ((vl-string-position 32 str nil t))
				 (0)
	    	(vla-update remain)
	    (setq no1 (mattrib-number-of-lines (vlax-vla-object->ename remain)))
	(mapcar	'(lambda (d)
		   (vlax-put remain (car d) (cadr d))
		'(("Layer" 0) ("Height" 10.0))
	(vl-cmdf "_.move"
		 "_none"
		 (Vlax-get remain 'Insertionpoint)
    (princ)
Take First Stringline
command: TFS
HTH
Message 20 of 51
tiwari1211
Hi kent, I hope you are doing well. will it be possible for you to add option for text rotation too in your code ?
So, when i copy the Mtext it ask for rotation angle. by default 0 deg.
Can you please help ?
