lisp to converts alot of objects to block in one time
pink_floid23
Message 1 of 28
pink_floid23
hi
i have this lisp convert object to block , but it make one by one , i need it fix to convert a lot of objects in one time to block ,(choose block by click on block or choose from list or insert be type new name )
Replies (27)
Message 21 of 28
ВeekeeCZ
Silly me, sorry about that. Fixed.
Message 22 of 28
EiPM_Xavi
A-M-A-Z-I-N-G !!
It works perfect: it's rock&Roll 😄
Thanks!
Xcoll
Message 23 of 28
s_pongpaitoon
Hi, any chance that we could edit this script to set the insertion point at the center of the selected object instead of 0, 0, 0?  Thanks in advance!!
Message 24 of 28
Sea-Haven
This needs to be replaced with a bounding box solution for multiple objects then get mid point. Check Lee-mac website Selection Set Bounding Box | Lee Mac Programming (lee-mac.com)
(not (setq i -1 pt (getpoint "\nSpecify Base Point: "))))
Message 25 of 28
jneesNTKKP
Can you help explain to me or help me make this block so I could set the name of the block. Hoping to be able to set the name and when it creates it would change the block in other locations within my drawing.
Message 26 of 28
ВeekeeCZ
Try this if it's what you need.
(defun c:Blockitinnotime (/ :AddLeadingZeros s o e n m x b l)
    (defun :AddLeadingZeros (a d / b) ;add zeros to 'd' many digits  ;a string
    (strcat (substr "000000000" 1 (if (>= d (setq b (strlen (itoa (fix (atof a)))))) (- d b) 0)) a))
  (setq n (getstring "\nSpecify block name prefix: "))
  (if (setq s (ssget '((-4 . "<NOT") (0 . "VIEWPORT,RAY,XLINE,INSERT") (-4 . "NOT>"))))
    (repeat (setq i (sslength s))
      (setq e (ssname s (setq i (1- i)))
;	    n (cdr (assoc 8 (entget e)))
	    l (assoc 8 (entget e)))
      (setq x 0)
      (while (tblsearch "BLOCK" (setq m (strcat n "_" (:AddLeadingZeros (itoa (setq x (1+ x))) 2)))))
      (entmake (list '(0 . "BLOCK") '(10 0 0 0) (cons 2 m) '(70 . 0)))
      (entmake (entget e))
      (and (= 1 (cdr (assoc 66 (entget (setq b e)))))
	   (while (not (= "SEQEND" (cdr (assoc 0 (entget (setq b (entnext b)))))))
	     (entmake (entget b)))
      (entdel e)
      (entmake '((0 . "ENDBLK") (8 . "0")))
      (entmake (list '(0 . "INSERT") (cons 2 m) l '(10 0 0 0)))))
  (princ)
Message 27 of 28
jneesNTKKP
thank you that does work, however if I wanted to remove the counting (added number) off at the end, where in the lisp can that change be made?
Message 28 of 28
faisal_kazi6RK49
Observer
Observer
SIMPLE SOLUTION GO TO RENAME AND BATCH UPDATE LIKE *varies* INTO A8 THEN ALL WILL UPDATE ONE TIME DIRECTLY
