LISP TO SPLIT TEXT
LISP TO SPLIT TEXT
pink_floid23
Message 1 of 8
LISP TO SPLIT TEXT
pink_floid23
HI
I need lisp can split the text to two text and two layers , split from letter or simple i enter it in command.
and the lisp work on a lot of texts  , not one by one
Replies (7)
Message 2 of 8
ВeekeeCZ
ALWAYS post 2 drawings. One this your current state, the second one with the wanted result.
btw the same applies to your another thread where you talking too much without much understanding.
Message 3 of 8
pink_floid23
thanks , i didn't know how to make lisp , i try to explain what i want ..
Message 4 of 8
hak_vz
@pink_floid23 Try this
(defun c:splittext ( / string_to_list e ent p1 cont nt del )
(defun string_to_list ( str del / pos )
(if (setq pos (vl-string-search del str))
(cons (substr str 1 pos) (string_to_list (substr str (+ pos 1 (strlen del))) del))
(list str)))
(setq e (car (entsel "\nSelect text >")))
(setq ent (entget e))
(setq p1 (cdr (assoc 10 ent)))
(setq cont (string_to_list (cdr (assoc 1 ent)) "-"))
(setvar 'cmdecho 0)
(while cont
(setq nt (car cont) cont (cdr cont))
(setq del (* 1.2(caadr(textbox ent))))
(command "_.copy" e "" p1 (setq p1 (polar p1 0 del)) "")
(setq e (entlast) ent (entget e))
(setq ent(subst (cons 1 nt) (assoc 1 ent) ent))
(setq ent(entmod ent))
(setvar 'cmdecho 1)
(princ)
Miljenko Hatlak
Message 5 of 8
pbejse
(Defun c:SplitMeBuddy (/ ss i e str p d ent ents pts pt ds)
  (if (setq ss (ssget "X" '((0 . "TEXT") (1 . "*-*mm"))))
    (repeat (setq i (sslength ss))
      (setq e	 (ssname ss (setq i (1- i)))
	    str	 (cdr (assoc 1 (setq ent (entget e))))
	    p	 (vl-string-position 45 str)
	    d	 (mapcar '(lambda (x) (assoc x ent)) '(11 50 1 40 7))
	    ent2 ent
      (setq pts	(textbox (Cddr d))
	    pt	(cdr (car d))
      (setq ds (* (- (caadr pts) (caar pts)) 0.25))
      (entmod
	(append	ent
		(list (cons 1 (substr str 1 p))
		      '(8 . "TS-SJ-TEXT")
		      (cons 11 (polar pt (+ pi (cdr (cadr d))) ds))
      (entmake
	(append	ent2
		(list (cons 1 (substr str (+ 2 p)))
		      '(8 . "TS-SJ-DIA")
		      (cons 11 (polar pt (cdr (cadr d)) ds))
  )(princ)
HTH
Message 6 of 8
pink_floid23
thank you very much 🌹
Message 7 of 8
pink_floid23
thank you very much 🌹 , and hope you make fix to the attribute block lisp
Message 8 of 8
hak_vz
@pink_floid23If you are satisfied with provided codes, accept them as solution (both @pbejse  and my solution).
Miljenko Hatlak
