Lisp to [check and close Polylines selected, Add a vertex in the longer straight side and make it the first vertex]
VincenzoPepe
Message 1 of 14
VincenzoPepe
Hi everyone,
I'm very new to lisp and need for your help,
I need for a lisp function to help me check polylines before sending to CNC machine.
I'm current working on autocad 2021 (don't know if lisp language is different by Autocad version)
I would like to achive this:
Sending parts to the CNC, to let the tool start from the middle of a long side, i need to check polylines i select to:
  • Close them if open,
  • Insert a vertex in the longest straight line,
  • make that vertex the first vertex,
here a example draft of the problem i need to solve.
Thanks in advance for helping.
Enzo
Replies (13)
Message 2 of 14
ВeekeeCZ
Possibly something like this.
(vl-load-com)
(defun c:PForCNC ( / s i j d e x m y)
  (if (setq s (ssget "_:L" '((0 . "LWPOLYLINE"))))
    (repeat (setq i (sslength s))
      (setq e (ssname s (setq i (1- i)))
	    d (entget e)
	    m (cdr (assoc 90 d))
	    x '(0 . 0)
	    j 0)
      (repeat (if (zerop (getpropertyvalue e "Closed")) (1- m) m)
	(and (setq j (1+ j))
	     (zerop (getpropertyvalue e "Vertices" (1- j) "Bulge"))
	     (setq y (- (vlax-curve-getdistatparam e j) (vlax-curve-getdistatparam e (1- j))))
	     (> y (cdr x))
	     (setq x (cons j y))))
      (setq d (append (vl-remove-if '(lambda (x) (vl-position (car x) '(10 40 41 42 91 90))) d)		; core
		      (list (cons 90 (1+ m)))
		      (list (cons 10 (vlax-curve-getpointatparam e (- (car x) 0.5))))   ; new vertex
		      (vl-member-if '(lambda (q) (equal q (cons 10 (reverse (cdr (reverse (vlax-curve-getpointatparam e (car x)))))) 1e-6)) d) ; from new vertex to the end
		      (reverse (cdr (vl-member-if '(lambda (q) (equal q (cons 10 (reverse (cdr (reverse (vlax-curve-getpointatparam e (car x)))))) 1e-6))
				      (reverse (vl-remove-if-not '(lambda (x) (vl-position (car x) '(10 40 41 42 91))) d))))))) 	; from core to new vertex.
      (vl-catch-all-apply 'entmod (list d))
      (vl-catch-all-apply 'setpropertyvalue (list e "Closed" 1))))
  (princ)
Message 3 of 14
ronjonp
What is the 'correct' solution for closing this example?
Message 4 of 14
Kent1Cooper
I would suggest forcing the closing of an open Polyline before looking for where to add a vertex, which would mean:
1.  You don't need to figure the number for that second (repeat) function differently depending on whether it's open or closed; and
2.  It allows for the possibility that the added closing segment could be the longest one, such as with an initial Polyline something like this:
Kent Cooper, AIA
Message 5 of 14
Sea-Haven
Message 6 of 14
komondormrex
hey there,
another one
(defun c:pline_cnc (/ param_index pline_object param_list max_length_index segment_list vertex_bulge_list)
	(foreach pline (vl-remove-if 'listp (mapcar 'cadr (ssnamex (ssget '((0 . "lwpolyline"))))))
		(setq param_index -1 param_list nil)
		(vla-put-closed (setq pline_object (vlax-ename->vla-object pline)) :vlax-true)
		(repeat (fix (vlax-curve-getendparam pline))
			(setq param_list (append param_list (list (setq param_index (1+ param_index)))))
		(vla-setbulge pline_object (last param_list) 0)
		(if (vl-some '(lambda (parameter) (zerop (vla-getbulge pline_object parameter))) param_list)
			(progn
				(setq max_length_index (car (vl-sort-i (mapcar '(lambda (segment) (if (zerop (vla-getbulge pline_object (car segment)))
															  						  (apply 'distance
																					  		 (mapcar '(lambda (param) (vlax-curve-getpointatparam pline param))
																							 		  segment
															  						  0
																(setq segment_list (mapcar 'list param_list (append (cdr param_list) '(0))))
				(vlax-invoke pline_object 'addvertex
										  (1+ max_length_index)
										  (mapcar '* '(0.5 0.5)
										  			  (mapcar '+ (vlax-curve-getpointatparam pline max_length_index)
																 (vlax-curve-getpointatparam pline (1+ max_length_index))
				(setq param_list (append param_list (list (1+ (last param_list))))
					  param_list (append (member (1+ max_length_index) param_list) (reverse (cdr (member (1+ max_length_index) (reverse param_list)))))
					  vertex_bulge_list (mapcar '(lambda (param) (list (vlax-curve-getpointatparam pline param) (vla-getbulge pline_object param))) param_list)
				(vlax-put pline_object 'coordinates (apply 'append (mapcar '(lambda (element) (mapcar '+ '(0 0) (car element))) vertex_bulge_list)))
				(mapcar '(lambda (bulge param) (vla-setbulge pline_object param bulge))
						 (mapcar 'cadr vertex_bulge_list)
						 (vl-sort param_list '<)
	(princ)
Message 7 of 14
VincenzoPepe
Hi ВeekeeCZ,
thanks a lot for your help,
I tested your code and I got some errors.
I've selected the three polylines together,
the first on the list (I think) has been closed,
then got this error:
"Select objects: 1 found, 2 total
Select objects: 1 found, 3 total
Select objects:
; error: bad argument type: lentityp nil"
I also tested the command one polyline by one and worked perfectly except on this polyline.
Here it did something strange, I can't understand.
text "current 1° vertex" indicates 1° vertex before the command is applied.
Message 8 of 14
VincenzoPepe
hi ronjonp, thanks for the reply
the red one is the correct solution.
Message 9 of 14
VincenzoPepe
Hi komondormrex,
thanks a lot for your help too,
I've tested your code too and I got again some errors.
once selected together the three polylines,
all three were closed, but the one on the left side with fillets on the corner with the 1° vertex, closed the polyline unexpectedly compared to if manually closed by Pedit command:
Pedit command recreates the fillet disappeared as I Opened the polyline on purpose for this demo test file.
I hope my explanation is clear.
Message 10 of 14
komondormrex
hey there,
i have done it purposely to avoid some unpredictable pline closings with unknown arc segment. you have tried a synthetic test of opening a closed  with certain arc pline. to retain a bulge of that arc segment comment out or delete line 8 in the code)
Message 11 of 14
ВeekeeCZ
Try the updated code. If you find more issues, post the dwg, not an image.
Message 12 of 14
VincenzoPepe
tnx,
I will try as soon as i can.
Message 13 of 14
VincenzoPepe
here it is,
Excuse me if didn’t do it before.
tnx again
Message 14 of 14
VincenzoPepe
Hi All,
I didn't pass the test I did on the cnc machine, but so far all the tests done worked perfectly with the komondormrex code with line 8 commented.
many thanks again to all of you.
Enzo
