CAD Boundary around the text or point
vishalghuge2500
vishalghuge2500
can we create a boundaries as shown with red lines from the left side drawing by using text base points
ВeekeeCZ
You can use this simple automation to help.
But - of course - you need to fix your drawing first. Seems like the FLATTEN fixed the most of it.
(vl-load-com)
(defun c:BoundaryT ( / s i p)
  (if (setq s (ssget '((0 . "TEXT"))))
    (repeat (setq i (sslength s))
      (setq p (cdr (assoc 10 (entget (ssname s (setq i (1- i)))))))
      (vl-catch-all-apply 'bpoly (list p))))
  (princ)
calderg1000
Regards @vishalghuge2500
Try this code, it should work if all the numbered areas had no unclosed encounters. Verify this first by zooming in on all the joints between lines that make up the vertices of the polygon to be obtained.
;;;___
(defun c:bop (/ x p)
  (foreach x
	     (vl-remove-if 'listp (mapcar 'cadr (ssnamex (ssget '((0 . "*text")))))
    (setq p (cdr (assoc 10 (entget x)))
	  p (mapcar '- p (list 0. 0. (caddr p)))
    (command "_.boundary" "_non" p "")
Carlos Calderon G
>Did you find this post helpful? Feel free to Like this post.
