LISP To Change MLeaders to By Layer
MrJSmith
MrJSmith
I can't get MLeader's arrow heads and leader lines to change color via LISP, ones created via the default "MLD" command. I am using the following command below to change everything to by layer. Referencing http://entercad.ru/acadauto.en/idh_mleader_object.htm, it says "The color of the leader line and arrowhead is controlled by the Color property, or by the DIMCLRD system variable.", yet the vlax-put-property color doesn't seem to be catching the heads/leader lines properly. I also tried adding the properties "LeaderLineColor" and "TrueColor" but neither attempt worked. Any ideas would be appreciated, thanks!
(defun All2BL ()
    (vlax-for block (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))
        (vlax-for obj block
            (if (wcmatch (vla-get-objectname obj) "AcDb*Dimension,AcDb*Leader")
				(progn
					(foreach prop '(Color DimensionLineColor ExtensionLineColor TextColor)
						(vl-catch-all-apply 'vlax-put-property (list obj prop acbylayer))
				(progn
					(vl-catch-all-apply 'vla-put-color (list obj acbylayer))
dbroad
You're trying to address too many object types with your function and are wrapping all of your actual changes in a vlax-catch-all-apply function, which will hide any and all errors.
Build a subfunction for mleaders and get that to work. Then restructure your code to branch on object type and to address each one as it should without the catch-all apply's.  The errors can then be debugged and testing on that object type will tell you more about what needs to change.
I believe all of the individual properties within the mleader should be byblock, not bylayer. Then there is a single control level for the drafter so that if they judge a color override is necessary, they can apply it.  Regarding color, the sub-objects may require an IAcadAcCmColor object. I never need to control sub-object colors since I use the mlstyle command to preset and use the properties palette to just change layer.
Architect, Registered NC, VA, SC, & GA.
MrJSmith
Looks like you are correct, it wants an IAcadAcCmColor object. I can't figure out how to modify the IAcadAcCmColor object.
Using  (vlax-get-property obj 'LeaderLineColor), returns #<VLA-OBJECT IAcadAcCmColor 000000003df349a0>
Using (vla-get-ColorIndex (vlax-get-property obj 'LeaderLineColor))), gives color index of 3, which is expected.
So I tried (vla-put-ColorIndex (vlax-get-property obj 'LeaderLineColor) 1)), which doesn't change anything.
I also tried using (vla-put-ColorMethod (vlax-get-property obj 'LeaderLineColor) 192) but that also failed to do anything.
dbroad
If you save the IAcadAcCmColor object, then you can change it and set the color of the subobject of the mleader.
Example:
(setq llc (vla-get-LeaderLineColor obj));;obtain the IAcadAcCmColor for the leaderline
(vla-put-ColorIndex llc 0);;set the color to byblock (use 256 for bylayer)
(vla-put-LeaderLineColor obj llc);;save it back to the leader subobject.
A color object can also be created by using vla-getinterfaceobject but that is needlessly complicated.  The properties and methods available for the IAcadAcCmColor object are:
; Property values:
; Blue (RO) = 0
; BookName (RO) = ""
; ColorIndex = 256
; ColorMethod = 192
; ColorName (RO) = ""
; EntityColor = -1073741824
; Green (RO) = 0
; Red (RO) = 0
; Methods supported:
; Delete ()
; SetColorBookColor (2)
; SetNames (2)
; SetRGB (3)
MrJSmith
Yes Sir, you are correct! I had that epiphany in the shower last night and tried it out this morning.
(setq colorObj (vlax-get-property obj 'LeaderLineColor))
(vla-put-ColorMethod colorObj 192)
(vlax-put-property obj 'LeaderLineColor colorObj)
Thanks for the help!
(defun All2BL (/ colorObj) ;Sets everything to by layer including leaders
		(vlax-for obj block
			(cond
				((wcmatch (vla-get-objectname obj) "AcDb*Dimension,AcDbLeader")
				((wcmatch (vla-get-objectname obj) "AcDbMLeader")
				(T
	(print "Everything has been set to by layer!")
	(princ)
