LISP to change layer "0" to another layer (existing layer or new layer)
nichkherbsman
nichkherbsman
LISP to change layer "0" to another layer (existing layer or new layer).
I need help, I am looking for lisp that will make all object in layer "0" to another layer (existing or new layer) including layer inside the block.
Because I have this drawing that some lines and text and objects are in default layer "0", I want the object in layer 0 to be assign in new layer.
Thank you.
NiCHKCiD
BIM Modeler
Technical Officer
Technical Designer
Sr. Draftsman
doaiena
I think this will work for you.
(defun c:test ( / ss lay )
(prompt "\nSelect objects from layer 0.")
(if (setq ss (ssget "_:L" '((8 . "0"))))
(progn
(setq lay (getstring "\nEnter a layer name: "))
(if (not (tblsearch "layer" lay))
(command "_.-layer" "_n" lay "")
(command "_chprop" ss "" "_LA" lay "")
));if ss
(princ)
);defun
ВeekeeCZ
(progn
(setq lay (getstring T "\nEnter a layer name: "))
));if ss
(princ)
);defun
...also would consider add the select option  "Enter a layer name <select object>: "
cadffm
A LAYMRG function for Layer0 is handle with care, it is really important to exlude some Blocks (i am sure you dont want to change the layer for all entities in a file 😉 )
Include attributes, Exlude unnamed (non dynamic) blocks, named system-blocks, xrefs..
So if you find one and you can not see or interpret the source code, handle with care.
Test 12x what it do exactly.
Dimensions, tables and more - check it exactly.
Sorry, i can not link to a GOOD tool (which a well exclude list), i am using my own (non public).
Sebastian
nichkherbsman
Thank you.
NiCHKCiD
BIM Modeler
Technical Officer
Technical Designer
Sr. Draftsman
