LISP to change crosshair Tint for X,Y,Z
D_Love
D_Love
Does anyone know how to use LISP to toggle this checkbox? (I'm using Civil3D if it matters)
Options->Display->Colors->[Context]->Crosshairs->Tint for X,Y,Z
The two specific contexts I care about are 2D model space and Sheet/Layout.
I've checked system variables, environment variables, object model, forums, etc and can't find it. Any help would be greatly appreciated.
pendean
Community Legend
Community Legend
@D_Love wrote:
..The two specific contexts I care about are 2D model space and Sheet/Layout.
May I confirm, you only want the ability to toggle x,y,z tint on and off in each tab/space, correct? AKA sometimes on sometimes off, with a manual trigger controlled by you
D_Love
Yes, that is the box I am wanting to change using LISP.
I may have used the word toggle wrong. Our company standard is to have it on all the time. I'm making a lisp routine that sets all company visual display standards that will be ideally only be run once when a new version of Civil3D is installed.
ВeekeeCZ
Try Registry, under profiles.
Computer\HKEY_USERS\***\SOFTWARE\Autodesk\AutoCAD\R24.1\ACAD-5100:409\Profiles\***\Drawing Window\Model Xhair use tint
paullimapa
from @ВeekeeCZ hint, this code should work:
(setenv "Model Xhair use tint" "1")
Paul Li
IT Specialist
@The Office
D_Love
Thanks. That is exactly what I was looking for. I also added the following line to apply the tint to layout tabs as well.
(setenv "Model Xhair use tint" "1") ;Tint croshairs on model tab
(setenv "Layout Xhair use tint" "1") ;Tint crosshairs on layout tabs
