LISP to change Attribute text color
burniksapwet
Message 1 of 22
burniksapwet
Guys,
           I need help from someone who could possibly create a LISP for us. Basically what we need is a way to change a block attribute to a different color. We want something that can be done on selected attributes. So let’s say for example a text attribute inside a block is "by layer" we would like a lisp to be able to change it to color 14 for example instead of having to do that one by one. At the same time we would also need something in reserve, meaning changing it back color 14 to “by layer." Thanks guys hope that you can help us out with this problem of ours. I know this request will be easy to some of you. Thanks for the help in advance.
Replies (21)
Message 2 of 22
tcorey
Using LISP is a great idea, but do you know about the block attribute manager? BATTMAN command. Take a look
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 3 of 22
leothebuilder
And if the BATTMAN command doesn't work, post your question here:
http://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/bd-p/130
Message 4 of 22
ВeekeeCZ
Try this easyone, using -attedit AutoCAD command.
(defun C:ATTEC (/ ss) ;Attribute Edit Color
  (command "_-attedit" "_y" "" "" "" PAUSE "" "_c" PAUSE "_n")
  (princ)
 If you want to BYLAYER, type simply BYLAYER instead of color number.
Message 5 of 22
Mr_J
BeekeeCZ, you rock! However I have a follow up question. Is there a way to select what color you want to change it to, and then pick ALL the ones you want to change? Or select EVERYTHING you want to change then run the lisp? Your command is great but it seems I have to type the color each time I run the command so when you have multiple blocks that have attributes it gets a bit tedious. Your lisp makes it very simple but I was curious if there was a way to make it that much easier.
Example: I will have tons of these kinds of symbols in a drawing and I will need to change a handful.
Message 6 of 22
hmsilva
Two different approaches:
(vl-load-com)
;; select multi blocks,
;; to change all selected attrubutes color...
(defun c:demo (/ blk col i ss)
  (if (and (princ "\nSelect blocks to change attributes color: ")
           (setq ss (ssget '((0 . "INSERT") (66 . 1))))
           (setq col (acad_colordlg 7))
    (repeat (setq i (sslength ss))
      (setq blk (vlax-ename->vla-object (ssname ss (setq i (1- i)))))
      (foreach att (vlax-safearray->list
                     (vlax-variant-value (vla-getattributes blk))
        (if (vlax-write-enabled-p att)
          (vla-put-color att col)
  (princ)
;; change attributes color by pick...
(defun c:demo1 (/ att col sel)
  (if (and (princ "\nEnter new attributes color: ")
    (while (and (setq sel (car (nentsel "\nSelect attribute text to change color: ")))
                (setq att (vlax-ename->vla-object sel))
                (= (vla-get-objectname att) "AcDbAttribute")
  (princ)
Hope this helps,
Henrique
Message 7 of 22
Mr_J
Fantastic!!! That is exactly what I needed thanks!
Message 8 of 22
hmsilva
You're welcome, Mr_J
Glad I could help
Henrique
Message 9 of 22
burniksapwet
Thanks for the solution hmsilva for the solution . This is exactly what we were looking for.
Message 10 of 22
hmsilva
You're welcome, burniksapwet
Glad I could help
Henrique
Message 11 of 22
kthmarks
Wow,  I have been looking for some time for a routine to do this.  If I may, if I wanted the routine to single out a specific attribute within selected blocks, how would that work?  The Attribute is called Bay# and I want to change it to color 90.
Hopefully some one can help.
Message 12 of 22
hmsilva
Untested...
(vl-load-com)
(defun c:demo (/ blk i ss)
    (if (and (princ "\nSelect blocks to change \"Bay#\" attributes to color 90: ")
            (foreach att (vlax-safearray->list (vlax-variant-value (vla-getattributes blk)))
                (if (and (vlax-write-enabled-p att)
                         (eq (vla-get-tagstring att) "Bay#")
                    (vla-put-color att 90)
    (princ)
Hope this helps,
Henrique
Message 13 of 22
kthmarks
Thank you for the effort.  I should have been clearer, the BAY# Attribute occurs in several different blocks, RackA, RackB, RackC.  The program would need to grab the Attribute within the blocks.  There are other attributes also in the block but it needs to only change BAY#.
Thank you for your help.
Message 14 of 22
hmsilva
It's your goal to change all attributes color in BAY# TAG in all the dwg without selecting the blocks?
Henrique
Message 15 of 22
kthmarks
No, only selected blocks.  I have a routine that lets me select one at a time (below) but the best scenerio would be to select specific blocks via (crossing) window and have that Bay# attribute change.  I guess the trick is that the attribute occurs in three different blocks, RackA, RackB, RackC.
Keep in mind, I know just enough to be dangerous.
(defun C:B2G (/ BIDSel BIDLoc)
(defun *error* (msg)
(princ "\nInvalid selection.")
(princ)
);_ end defun *error*
(defun SelectID (msg)
(setq BIDLoc (cadr (setq BIDSel (entsel (strcat "\nPick " msg " to Change: ")))))
);_ end defun SelectID
(defun CHGIt (/)
(command "-attedit" "y" "" "" "" BIDLoc "" "C" "90" "" "")
);_ end defun CHGIt
(setvar "cmdecho" 0)
(SelectID "attribute")
(CHGIt)
(while BIDSel
(SelectID "next attribute")
(if (= (type BIDSel) 'list)
(CHGIt)
(setq BIDSel nil)
) ;_ end if
) ;_ end while
(princ)
Message 16 of 22
hmsilva
If in 'Bay#' # it's not a wildcard... the code in message #12 should work as expected.
If not, post a sample dwg with with some blocks.
Henrique
Message 17 of 22
kthmarks
Thanks Henrique.  No, it didn't work.  Attached is a sample drawing.
To clarify further,multiple blocks have the same attribute.  I have attached a revised sample.
Message 18 of 22
hmsilva
As my friend @ВeekeeCZ as as detected... it was a text case issue... BAY# Bay#...
Revised code...
(vl-load-com)
                         (eq (strcase (vla-get-tagstring att)) "BAY#")
    (princ)
Hope this helps,
Henrique
Message 19 of 22
kthmarks
Perfect!  Thank you, I really appreciate your help with this.
Message 20 of 22
hmsilva
You're welcome!
Glad I could help 🙂
Henrique
