Lisp to change all text on a layer to same word
Hi all,
I'm looking for a lisp that will allow me to select all text on a personnel layer and change all the text to the same word.  Ex. I have "100 different personnel names" and I'd like to change all of them to  say"WS".  Is this possible?
ronjonp
Sure:
(defun c:foo (/ s)
  (if (setq s (ssget ":L" '((0 . "TEXT") (8 . "personnel"))))
    (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))
      (entmod (append (entget e) '((1 . "WS"))))
  (princ)
Or for no selection needed:
(defun c:foo (/ s)
  (if (setq s (ssget "_X" '((0 . "TEXT") (8 . "personnel"))))
    (foreach e (mapcar 'cadr (ssnamex s)) (entmod (append (entget e) '((1 . "WS")))))
  (princ)
This can also be accomplished by using a little snippet like this and changing whatever property you'd like in the properties palette.
(sssetfirst nil (ssget "_X" '((0 . "TEXT")(8 . "personnel"))))
Or use the FILTER command. Many ways to skin this cat.
Kent1Cooper
Another approach, posted mostly because it also includes Mtext  if you need that:
(defun C:TEST (/ ss n)
  (if (setq ss (ssget "_X" '((0 . "*TEXT") (8 . "YourLayerName"))))
    (repeat (setq n (sslength ss))
      (vla-put-TextString (vlax-ename->vla-object (ssname ss (setq n (1- n)))) "WS")
  (princ)
Kent Cooper, AIA
It worked! Thanks for saving me so much time!
ronjonp
