Lisp to calculate area of all closed polylines selected
MikeKovacik4928
Advisor Advisor
Message 1 of 8
MikeKovacik4928
Hi there Autocadders world wide as well as Autodesk employees
Can someone give me a lisp that calculates the area of all closed polylines selected, (in one operation)
The area add command is okay, except if you have over a hundred closed polylines
whose areas you want to add up, then selecting over a hundred entities separately becomes tedious
Mike Kovacik
Autocad/Inventor 2d/3d draughtsman/designer
Joburg
South Africa
Replies (7)
Message 2 of 8
JTBWorld
Maybe this can help. AreaM.lsp Calculates the total area of selected objects
Jimmy Bergmark
JTB World - Software development and consulting for CAD and license usage reports
https://jtbworld.com
Message 3 of 8
MikeKovacik4928
Perfect Jimmy !!!
Mike
Message 4 of 8
Jimmy,
I installed the lisp that calculates the total area of multiple objects at once, but it doesn't appear to be working. After I run the AreaM command and select the objects, the dynamic input/command line goes blank and I don't get a measurement.
Thoughts?
Message 5 of 8
JTBWorld
What does the command line history show, what type of objects and what version of AutoCAD?
Jimmy Bergmark
Message 6 of 8
jleeNJTPV
Community Visitor
Community Visitor
Is there a way for the command to work by selecting all the polylines first, then running AREAM? Currently it only works if you run the command before selecting the polylines.
Message 7 of 8
BlackBox_
This should help; it accepts implied selection, and *IF* you have loaded DosLIB, it will copy the result to clipboard:
(vl-load-com)
(defun c:AreaM (/ *error* acDoc ss area prec)
  (defun *error* (msg)
    (if ss (vla-delete ss))
    (cond ((not msg))                                                   ; Normal exit
          ((member msg '("Function cancelled" "quit / exit abort")))    ; <esc> or (quit)
          ((princ (strcat "\n** Error: " msg " ** ")))                  ; Fatal error, display it
    (princ)
  (if (ssget "_:L"
             '((-4 . "<OR")
               (0 . "POLYLINE")
               (0 . "LWPOLYLINE")
               (0 . "CIRCLE")
               (0 . "ELLIPSE")
               (0 . "SPLINE")
               (0 . "REGION")
               (-4 . "OR>")
    (progn
      (vlax-for	x (setq	ss
			 (vla-get-activeselectionset
			   (setq acDoc (vla-get-activedocument
					 (vlax-get-acad-object)
	(setq area (cons (vla-get-area x) area))
      (prompt (strcat "\nTotal area: "
                      (rtos (setq area (apply '+ area)))
;;; example for reporting the area in multiple units:
;;;		      (rtos (setq area (apply '+ area)) 2 (setq prec (getvar 'luprec)))
;;;		      " SF | "
;;;		      (rtos (/ area 9.0) 2 prec)
;;;		      " SY | "
;;;		      (rtos (/ area 43560.0) 2 prec)
;;;		      " AC "
      ;; if doslib is available, copy result to clipboard
      (if dos_clipboard (dos_clipboard (rtos area)))
  (*error* nil)
HTH
"How we think determines what we do, and what we do determines what we get."
Sincpac C3D ~ Autodesk Exchange Apps
Message 8 of 8
Sea-Haven
Just a comment it makes sense to me to say sort the plines based on say layer names, then can make say a table of the resulting total area by layer. Yes have send a table to Excel or just write answer to Excel.
