LISP to automatically generate results with maximum and minimum value for each attribute from multiple block references
afloareirazvan
afloareirazvan
Hello.
These are the names of my attributes and I want to generate results with maximum and minimum value for each attribute from a bunch of block references
Thank you for your time.
paullimapa
Questions:
1. Do you have in your drawing one Block that has all these Attributes but inserted multiple times or do you have a number of different named Blocks that contain some of these Attributes?
2. How are you expecting the results to return back to you after the code runs? For example: as a list that contains the name of the Attribute followed by maximum & then minimum values ie: ((I-ID (4 1)) (I-V (25 10))...) or dotted pair ie:
((I-ID . (4 1)) (I-V . (25 10))...) or ...?
Paul Li
IT Specialist
@The Office
vladimir_michl
There is the AutoClass tool which can classify DWG objects by some property (incl. numeric value of a selected attribute). So the max/min is then easy to see. But it may be too general for your task. See https://www.cadstudio.cz/en/apps/autoclass/
Vladimir Michl, www.arkance-systems.cz - www.cadforum.cz
john.uhden
@afloareirazvan
Would this be for all the insertions in a drawing or for just a selection of inserts?
Do all the attribute values contain strictly numeric text?
Would any of the values be in architectural format?
Would an empty attribute have a value of 0?
Could you please provide a sample drawing and the list of attribute tags as text?
John F. Uhden
3wood
You can ATTOUT the attribute values and then use MS Excel to sort it.
john.uhden
@3wood
I've never used ATTOUT.  Can you include the tags?
John F. Uhden
Sea-Haven
