Lisp to add multiple nubered line types.
arpansark0544TCX
arpansark0544TCX
Hello everyone hope you are doing good.
In pursuit to solve my complex electrical conducting problem, I need help in Lisp which can add multiple line types.
I am attaching DWG and some photos of what should be the result. Along with my Custom.Lin file.
Thank you.
vladimir_michl
Do you mean the existing numbers should be added to auto-create a new linetype? I have no solution for that but the utility LtFly can help to create new linetypes on-the-fly, just by specifying the label text. See:
https://www.cadforum.cz/en/create-autocad-complex-linetypes-on-the-fly-tip7147
Vladimir Michl, www.arkance-systems.cz  -  www.cadforum.cz
hak_vz
@arpansark0544TCX
Modified from solution to your previous request. Don't have time to modify code to work with lines and polylines so only use lines. You didn't have to open new post.
(defun c:add_C_lines ( / *error* duplicates ss e ent i ptlist p ovl old_expert dup)
	(defun *error* ( msg )
		(if (not (member msg '("Function cancelled" "quit / exit abort")))
			(princ)
		(setvar 'cmdecho 1)
		(setvar 'expert old_expert)
		(vla-endundomark adoc)
		(princ)
	(defun duplicates ( lst )
		(if lst
			(if (member (car lst) (cdr lst))
				(cons (car lst) (duplicates (vl-remove (car lst) (cdr lst))))
	(setq adoc (vla-get-ActiveDocument (vlax-get-acad-object)))
	(vla-startundomark adoc)
	(setq old_expert (getvar 'expert))
	(setq ss (ssget "X" '((0 . "LINE")(8 . "EE-POWER CIRCUIT"))) i -1)
	(setvar 'cmdecho 0)
	(while (< (setq i (1+ i)) (sslength ss))
		(setq
			ent (entget (ssname ss i))
			a (cdr (assoc 10 ent))
			b (cdr (assoc 11 ent))
			ptlist (cons (mapcar 'fix (mapcar '* '(0.5 0.5)(mapcar '+ a b))) ptlist)
	(foreach pt (duplicates ptlist)
		(setq ss (ssget "_C" (mapcar '+ '(15 15) pt) (mapcar '+ '(-15 -15) pt) '((0 . "LINE"))))
		(setq i -1 cnt 0)
			(setq cnt (+ cnt (atoi(substr (cdr (assoc 6 (entget(ssname ss i))))2))))
			(if (>= i 1)(entdel (ssname ss i)))
		(setq e (ssname ss 0))
		(command "_.linetype" "load" (strcat "C" (itoa cnt)) "acad.lin" "")
		(command "_.chprop" e "" "LTYPE" (strcat "C" (itoa cnt)) "")
	(setvar 'cmdecho 0)
	(princ "\nDone!")
	(princ)
Miljenko Hatlak
arpansark0544TCX
Is there any modification needed in the code to do for other Letters?
My final design with the help of lisp. The complex network of conduits are reduce to some numbered line in different layers and line types.
hak_vz
@arpansark0544TCX
Later today, if I find some time, I'll make adjustments so that you can select other base layer and destination layer, and to define used linetype group i.e. C D E or whatever. You can also write all your other requests so we can add it to final code.
Miljenko Hatlak
