09:21 AM
Hello - I have a number of drawings that contain numerous instances of a block named TAG-PART. This block contains a number of attributes, one of which is FRAME-QTY.
What I would like to do is to link the value of this attribute in all instances of the block to a custom property in the drawing called QUANTITY.
Right now I have the following code that reads the value of QUANTITY and updates the attribute value, but does not link it.
Any help would be appreciated.
;; Definition: Program
(defun c:QtyLinkSetup ()
;; Load ActiveX
(vl-load-com)
;; Definition: blkset
;; Args: blname
;; Example: (blname "11x17_Fabrication_TB-2013")
(defun blkset (blname)
(if
(not (setq sset (ssget "X" (list (cons 2 blname)))))
(setq sset (ssadd))
);end if
(if
(setq ss-dyn (ssget "X" (list (cons 2 "`*U*"))))
(progn
(setq num 0)
(repeat (sslength ss-dyn)
(setq ent (ssname ss-dyn num))
(setq effname (vla-get-EffectiveName (vlax-ename->vla-object ent)))
(if
(= blname effname)
(ssadd ent sset)
);end if
(setq num (1+ num))
);end repeat
);end progn
);end if
sset
);end defun
;; Get Quantity value in drawing properties custom tab
(setq acadObject (vlax-get-acad-object)
acadDocument (vla-get-ActiveDocument acadObject)
suminfo (vlax-get-Property acadDocument 'SummaryInfo)
);end setq
(vla-getCustomByKey suminfo "QUANTITY" 'qty)
;; Get "TAG-PART" blocks and link quantity value to drawing custom properties quantity
(setq blname "TAG-PART"
sset nil
ss1 (blkset blname)
memb 0
);end setq
(if ss1
(repeat (sslength ss1)
(progn
(setq entname (vlax-ename->vla-object (ssname ss1 memb))
entlist (vlax-safearray->list (vlax-variant-value (vla-getattributes entname)))
);end setq
(vla-put-textstring (nth 5 entlist) qty)
(setq memb (1+ memb))
);end progn
);end repeat
);end if
;; End routine
(princ)
);end progn
