Lisp to add link to block attribute
Hello - I have a number of drawings that contain numerous instances of a block named TAG-PART.  This block contains a number of attributes, one of which is FRAME-QTY.
What I would like to do is to link the value of this attribute in all instances of the block to a custom property in the drawing called QUANTITY.
Right now I have the following code that reads the value of QUANTITY and updates the attribute value, but does not link it.
Any help would be appreciated.
;; Definition: Program
  (defun c:QtyLinkSetup ()
;; Load ActiveX
    (vl-load-com)
;; Definition: blkset
;; Args: blname
;; Example: (blname "11x17_Fabrication_TB-2013")
    (defun blkset (blname)
      (if
        (not (setq sset (ssget "X" (list (cons 2 blname)))))
	(setq sset (ssadd))
      );end if
      (if
        (setq ss-dyn (ssget "X" (list (cons 2 "`*U*"))))
	(progn
	  (setq num 0)
	  (repeat (sslength ss-dyn)
	    (setq ent (ssname ss-dyn num))
	    (setq effname (vla-get-EffectiveName (vlax-ename->vla-object ent)))
	    (if
              (= blname effname)
	      (ssadd ent sset)
	    );end if
	    (setq num (1+ num))
	  );end repeat
	);end progn
      );end if
      sset
    );end defun
;; Get Quantity value in drawing properties custom tab
    (setq acadObject   (vlax-get-acad-object)
          acadDocument (vla-get-ActiveDocument acadObject)
          suminfo      (vlax-get-Property acadDocument 'SummaryInfo)
    );end setq
    (vla-getCustomByKey suminfo "QUANTITY" 'qty)
;; Get "TAG-PART" blocks and link quantity value to drawing custom properties quantity
    (setq blname "TAG-PART"
          sset nil
          ss1 (blkset blname)
          memb 0
    );end setq
    (if ss1
      (repeat (sslength ss1)
	(progn
          (setq entname (vlax-ename->vla-object (ssname ss1 memb))
	        entlist (vlax-safearray->list (vlax-variant-value (vla-getattributes entname)))
          );end setq
          (vla-put-textstring (nth 5 entlist) qty)
	  (setq memb (1+ memb))
	);end progn
      );end repeat
    );end if
;; End routine
    (princ)
  );end progn
hmsilva
Hi gpeneltonHSYMG,
if by 'link it' you mean using a FIELD, try to change
to
(vla-put-textstring (nth 5 entlist) "%<\\AcVar CustomDP.QUANTITY>%")
and a regen should be required...
Hope this helps,
Henrique
That works perfectly!
Thanks very much Henrique.
hmsilva
You're welcome, gpeneltonHSYMG
Glad I could help
Henrique
