LISP that inserts different block based on user input
BL_Apex
BL_Apex
I'm trying to create a tool that will insert the correct sized block based on a number input from the user. Example:
User runs the LISP
User is prompted to input a number
  • If user specified number is less than 250, then insert Block A
  • If user specified number is 250 or greater and less than 500, then insert Block B
  • If user specified number is 500 or greater, then insert Block C
Note: The number the user is inputting may be a decimal
I know how to do basic If statements but I'm not sure how to handle a list of conditions or work with ranges of numbers.
Any help is appreciated!
Kent1Cooper
@BL_Apex wrote:
.... I'm not sure how to handle a list of conditions or work with ranges of numbers.
Your terminology is right on.  This is a perfect application of the (cond) function [read about it].  For example:
(setq num (getreal "\nThe number: "))
(command "_.insert"
  (cond ; determine Block name from numerical range
    ((< num 250) "BlockA")
    ((< num 500) "BlockB")
    ("BlockC")
  ); cond
  .... on to insertion point, etc.....
Kent Cooper, AIA
pbejse
User runs the LISP
(defun c:demo (/ d)
(initget 6)
  (princ
    (Strcat "\nBlock to insert: "
	    (cond
	      ((not (setq d (getreal "\nEnter number:"))))
	      ((< d 250) "Block A")
	      ((<= 250 d 500) "Block B")
	      ((> d 500) "Block C")
  )(princ)
HTH
BL_Apex
@Kent1Cooper @pbejse thank you both for the working solutions! I knew it was simple I just couldn't get it formatted correctly.
In the event that I wanted to have a maximum value, let's say 2000, is there a way that the "otherwise" part of the statement could be set up to read "Invalid input. Enter number between 0 and 2000" on the command line and  prompt the user for another input?
Kent1Cooper
The asking again part is much easier if that check and prompt are in the getting-the-number part, rather than a none-of-the-above condition when already in the Insert command:
(while
  (and
    (not (initget 4)); no negative [0 permitted] {wrapped in (not) because (initget) returns nil}
    (setq num (getreal "\nNumber between 0 and 2000: "))
    (> num 2000)
  ); and
  (prompt "\nInvalid input. Enter number between 0 and 2000")
); while
(command "_.insert"
    ("BlockC")
  ); cond
Kent Cooper, AIA
BL_Apex
Excellent. Makes perfect sense.
pbejse
(defun BlockNameIsValid ( lmt  / d)
(initget 5)
    (cond
      ((not (setq d (getreal (strcat "\nEnter number between 0 and "
				     (rtos lmt 2 0) ": "))))
      ((<  500 d lmt) 	"Block C")
      (t (alert "Invalid input") (BlockNameIsValid lmt))
Usage
(BlockNameIsValid 2000)
(BlockNameIsValid 5000)
Enter number between 0 and 5000
HTH
