Alphanumeric sort
Alphanumeric sort
drew_dewit
Message 1 of 9
Alphanumeric sort
drew_dewit
I am looking to sort the following list ("U20" "U10" "U110" "U11" "T1" "V1") to first be sorted alphabetically then numerically so that it ends up being ("T1" "U10" "U11" "U20" "U110" "V1")  this is the funtion I am currently using
(defun sort (l)
(defun sortFunc (m n)
(< (car m) (car n))
(vl-sort l 'sortFunc)
This works fine till you get to a 3 digit number then it tries to do ("T1" "U10" "U11" "U110" "U20" "V1").
Any suggestions?
Replies (8)
Message 2 of 9
pbejse
Any suggestions?
Suggestion: You need to split them so you can effectively sort the numeric values.
Let us know if you need help with that.
Message 3 of 9
drew_dewit
That would be, I figured that was the route to go but don't have a good grasp on the best way to do that.
Message 4 of 9
hak_vz
As @pbejse  suggests
(setq lst '("U20" "U10" "U110" "U11" "T1" "V1"))
(foreach e lst(setq ret (cons (list (substr e 1 1)(atoi(substr e 2)))ret)))
New list ret is then
(("V" 1) ("T" 1) ("U" 11) ("U" 110) ("U" 10) ("U" 20))
Miljenko Hatlak
Message 5 of 9
Kent1Cooper
If they always start with a single letter followed by only numbers representing integers, this seems to work:
(defun SortAI (lst); = Sort Alphabetically, and within that by Integer value
  (vl-sort
    (vl-sort lst '(lambda (a b) (< (atoi (substr a 2)) (atoi (substr b 2)))))
    '(lambda (c d) (< (substr c 1 1) (substr d 1 1)))
It sorts by the numbers "inside," ignoring the letters and using numerical rather than alphabetical values for the numbers, then "outside" sorts that result by the initial letters, and those entries that share an initial letter stay, among themselves, in the order from the numerically-sorted result.
(SortAI lst)
(setq lst '("F123" "T4" "A23" "Q3450" "F13" "A8" "T1"))
(SortAI lst)
  ("A8" "A23" "F13" "F123" "Q3450" "T1" "T4")
Kent Cooper, AIA
Message 6 of 9
pbejse
One example
(defun _n (str / s)
  (setq s (vl-string-right-trim "0123456789" str))
  (list s (atoi (substr str (1+ (strlen s)))))
_$ (_n "U101")
("U" 101)
_$ (_n "UBN101")
("UBN" 101)
(Defun sortFunc (l)
(Vl-sort l'(lambda (n m)
		(setq n (_n n) m (_n m))
			(cond
			  ((< (Car n) (car m)))
			  ((eq (Car n) (car m)) (< (Cadr n) (cadr m)))
_$ (setq lst '("U20" "U10" "U110" "U11" "T1" "V1"))
_$ (Acad_strlsort lst)
_$ (sortFunc lst)
_$ (setq lst '("U20" "U10" "U110" "U11" "T1" "V1" "HE110" "HE250" "HE2"))
("HE110" "HE2" "HE250" "T1" "U10" "U11" "U110" "U20" "V1")
_$ (sortFunc lst)
("HE2" "HE110" "HE250" "T1" "U10" "U11" "U20" "U110" "V1")
HTH
Message 7 of 9
drew_dewit
Thanks guys,
@Kent1Cooper
So this function works
  (vl-sort
However I was wrong in how the list is presented to the function. Its actually a list of lists. So it looks like (("A10" Description" "Rev")("B100" "Description" "Rev" ...)
How can i modify this to sort by the first element of the sub lists. I imagine I can insert a CAR but I'm not sure the best way.
Message 8 of 9
Kent1Cooper
@drew_dewit wrote:
... I was wrong in how the list is presented to the function. Its actually a list of lists. So it looks like (("A10" Description" "Rev")("B100" "Description" "Rev" ...)
I hope this will do that [untested]:
(defun SortAI (lst); = Sort Alphabetically, and within that by Integer value [of first element]
  (vl-sort
    (vl-sort lst '(lambda (a b) (< (atoi (substr (car a) 2)) (atoi (substr (car b) 2)))))
    '(lambda (c d) (< (substr (car c) 1 1) (substr (car d) 1 1)))
Kent Cooper, AIA
Message 9 of 9
pbejse
FWIW:
(defun _n (str / s)
(Defun ThisFunc (l) (Vl-sort l'(lambda (n m) (setq n (_n (Car n)) m (_n (Car m))) (cond ((< (Car n) (car m))) ((eq (Car n) (car m)) (< (Cadr n) (cadr m))) ) ) ) )
(setq lst '(("A10" "Description" "Rev")("U20" "Description" "Rev")("B100" "Description" "Rev")
	    ("U10" "Description" "Rev")("HE110" "Description" "Rev")("U110" "Description" "Rev")
	    ("HE2" "Description" "Rev")))
(ThisFunc lst)
("A10" "Description" "Rev") ("B100" "Description" "Rev") ("HE2" "Description" "Rev")
("HE110" "Description" "Rev")("U10" "Description" "Rev") ("U20" "Description" "Rev")
