LISP that converts 3D polyline to solid
LukasA-HAK
Message 1 of 49
LukasA-HAK
I am a surveyor at a pipe construction company.
The preliminary design requires data from pipeline traces of other companies that are already in the ground with their pipeline traces
Test trenches must be dug for this purpose.
The engineering firm wants this data to be supplied in autocad solids 3D. With the pipe data in the layer name.
The work process for this is now:
Create layer name. Place circle with diameter pipe on 3D polyline. Apply command sweep along path. Then I still have to move the solid because the top of the pipes have been measured.
This must be done manually for each pipe. Sometimes I'm busy for days.
Isn't there an autocad lisp routine that can automate this work??
It would be nice if this lisp could retrieve the diameter from, say, the layer name.
Accepted solutions (3)
Replies (48)
Message 21 of 49
LukasA-HAK
Here are 2 GPS files of a measured test trench measured with GPS.
The first is the START file as it comes out of the GPS device.
The second is the converted measurement file using ВeekeeCZ's awesome LIPS routine.
Message 22 of 49
LukasA-HAK
The second is the converted measurement file using ВeekeeCZ's sophisticated LIPS routine
Message 23 of 49
LukasA-HAK
Is the second part also possible to make?
Message 24 of 49
ВeekeeCZ
@LukasA-HAK wrote:
This works great. How did you do this??
(foreach point from all-points-sorted-incrementally-by-no
   (if 	(and 	this point no is 1+ previous point no
		this point desc is the same or same+suffix as the previous point desc
		angle between current and previous segment is more than 88°)
         then add this point to the previous one to create a line, desc of 1st one use as layer name
	 else start a new line.
  (if 	line has only one point
	then add 2nd pnt with 1st+(dx=dy=0.02) and color them.
Message 25 of 49
LukasA-HAK
Should this be added to the code?
Message 26 of 49
ВeekeeCZ
Well, I thought that you want to know how the program works. So I've tried to explain the main algorithm but I see... still too much. My bad. I've better keep silence.
Message 27 of 49
LukasA-HAK
I thought so
I try to understand Autocad Lisp. I read about it. I can't say I think it's simple.
Message 28 of 49
Sea-Haven
Can you supply the GPS data file not a dwg I still think better to string based on the field GPS survey, so need to see what is in a file. Spent last 40 years working with Field surveys and feature coding.
Message 29 of 49
LukasA-HAK
I regret that I only see how powerful LISP is after 23 years
Message 30 of 49
LukasA-HAK
These are the raw measurement data of the test trench in question.
The names are in Dutch, but I don't think that will matter for the processing of the data.
However, automation has not yet been taken into account during the measurement.
It might be an idea if I create a text file using data extraction.
Message 31 of 49
LukasA-HAK
This is the data as that data extraction creates. A csv file is also possible. This is a simplified file of the same test trench
Message 32 of 49
LukasA-HAK
Hi, this is the csv file of the measured points
Message 33 of 49
Sea-Haven
Thank you for the files I will try to get a similar file for a dwg so can show how stringing works, I think can do something with what you have. Based on codes as stringing.
Can you PM me your email as I think will have a bit of back and forth.
Message 34 of 49
LukasA-HAK
Thank you.
I will try to understand lisp asap
My email adress is [email protected]
Message 35 of 49
LukasA-HAK
It is possible that e-mail is initially blocked by the system.
Message 36 of 49
Sea-Haven
Edit your post better to not post emails in public you can use private mail for stuff like that. I have it now.
Message 37 of 49
ВeekeeCZ
Not sure whether you still follow this route but since is quite simple here you go.
You need to select 3dpolys in *#mm* layers where # is considered a diameter.
The current dwg is probably in mm, so either scale the drawing to m or change (/ d 2.) to (/ d 2000.) in the code.
Remove the semicolon from (entdel e) line if you want to 3dpolys be removed.
(vl-load-com)
(defun c:sweepalong ( / *error* lay doc i e l d x)
  (defun *error* (errmsg)
    (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break,end"))
      (princ (strcat "\nError: " errmsg)))
    (if lay (setvar 'clayer lay))
    (vla-endundomark doc)
    (princ))
  (setq lay (getvar 'clayer)
	doc (vla-get-activedocument (vlax-get-acad-object)))
  (if (and (setq s (ssget '((0 . "POLYLINE") (8 . "*#mm*"))))
	   (not (vla-startundomark doc)))
    (repeat (setq i (sslength s))
      (setq e (ssname s (setq i (1- i)))
	    l (cdr (assoc 8 (entget e)))
	    d (atof (substr l (1+ (strlen (vl-string-right-trim "0123456789." (substr l 1 (vl-string-search "mm" l))))))))
      (setq x (entmakex (list '(0 . "CIRCLE") '(10 0 0 0) (cons 8 l) (cons 40 (/ d 2.)))))
      (setvar 'clayer l)
      (command "_.move" e "" "_d" "_non" (list 0 0 (/ d -2.))
	       "_.sweep" x "" e "")
      (entdel x)
      ;(entdel e)
  (*error* "end")
Message 38 of 49
LukasA-HAK
I have tested the program.
We work in metres. I modified the program and it works great!
Because we also work with another measurement system, I also want to continue with the string solution from Sea-Haven.
Message 39 of 49
LukasA-HAK
Hi BeekeCZ, when trying to run the program to other measurement files it gives the following  error: Error: ADS request error.
Ik don`t get where this error comes from...
What is the minimum information the LISP code needs to have?
Message 40 of 49
LukasA-HAK
About the connectpoints lisp:
I think it works now.
I looked into the test file.
I think you made the following adjustments
- First insunits 0; insunitsdeftarget 0;insunitsdefsource feet) units to surveyor settings; (grads; direction north; clockwise)
- Layer created layer1 and made current.
- Then Wblock > autocad 2007 file,
