Lisp Table
Lisp Table
Lex_van_Ham
Message 1 of 19
Lisp Table
Lex_van_Ham
 Is there a way I can make a table with values in there using lisp?
Replies (18)
Message 2 of 19
DannyNL
Yes, you can. Many examples can be found in this forum or other forums.
Check the thread below for one of those many examples; my code creates a table with information collected from the drawing in this case.
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/lisp-request-block-count-inside-a-cl...
Message 3 of 19
_gile
You can use the ActiveX vla-AddTable function to create the table and the use the Table object methods and properties
Gilles Chanteau
GileCAD
GitHub
Message 4 of 19
Lex_van_Ham
Im not sure if its included in your last reply (probably is but i can't find/don't understand it) but how would i use the same lisp script to put text/number/other stuff into the cells like a-2 = 10 or something.
Message 5 of 19
ВeekeeCZ
Well, tables are not that simple to handle that after couple of days of learning LISP. Rather post your idea what it should look like and we may help you to make that happen.
Message 6 of 19
Lex_van_Ham
Oke so:
I want a table with 2 columns 28 rows with in the top row the table name
Below that the names of the columns
All the rows below that Column 1 will always have the same name with exeption for row 5 and 6 They will be like:
(cond
    (Different product
and so on.
Column 2 will be the amount of items based on calculations from my last script.
Example:
Message 7 of 19
_gile
Here's an example from which you should get som inspiration.
It creates a table to list the selected block references.
(defun c:listBlock (/ ss name ref refs insPt table row)
  (vl-load-com)
  (or *acdoc*
      (setq *acdoc* (vla-get-ActiveDocument (vlax-get-acad-object)))
  (or *blocks*
      (setq *blocks* (vla-get-Blocks *acdoc*))
  (prompt "\nSelect blocks to list or <All>")
  (or (setq ss (ssget '((0 . "INSERT"))))
      (setq ss (ssget "_X" '((0 . "INSERT")))
  (if ss
    (progn
      (vlax-for	x (setq ss (vla-get-ActiveSelectionSet *acdoc*))
	(if (not (vlax-property-available-p x 'Path))
	  (setq	name (vla-get-EffectiveName x)
		refs (if (setq ref (assoc name refs))
		       (subst (cons name (1+ (cdr ref))) ref refs)
		       (cons (cons name 1) refs)
      (vla-delete ss)
      (initget 1)
      (setq insPt (trans (getpoint "\nInsertion point: ") 1 0))
      (setq table (vla-addtable
		    (vla-get-modelspace *acdoc*)
		    (vlax-3d-point insPt)
		    (+ 2 (length refs))	; number of rows (including title and header)
		    3			; number of colums
		    20			; cell height
		    80			; row width
      (vla-put-VertCellMargin table 4.0)
      (vla-put-TitleSuppressed table :vlax-false)
      (vla-put-HeaderSuppressed table :vlax-false)
      (vla-setText table 0 0 "Blocks")
      (vla-setText table 1 0 "Name")
      (vla-setText table 1 1 "Count")
      (vla-setText table 1 2 "Symbol")
      (setq row 2)
      (foreach item refs
	(vla-settext table row 0 (car item))
	(vla-settext table row 1 (cdr item))
	(vla-SetBlockTableRecordId
	  table
	  row
	  2
	  (vla-get-ObjectId (vla-Item *blocks* (car item)))
	  :vlax-true
	(setq row (1+ row))
  (princ)
Gilles Chanteau
GileCAD
GitHub
Message 8 of 19
ВeekeeCZ
Lets start from the beginning. Are you able to build a list of values for your table? It should look like this:
'(("name1" "amount1")
  ("name2" "amount2")
  ("name3" "amount3")
  ("name4" "amount4")
  ("name16" "amount16")
Message 9 of 19
DannyNL
And looking at your example table.......what are you exactly counting?
If you are counting blocks in the current drawing or in a set of drawings, this might be easily solved by using the Extract Data tools (Ribbon Insert-> Panel Linking & Extraction --> Extract Data) as this will be able to count and automatically create a table for you.
Message 10 of 19
Lex_van_Ham
Like this?
If you mean replace the name of "name1" to what ever it will be when done ill do that when I got the entire thing working.
  ("name2" "amount2")
  ("name3" "amount3")
  ("name4" "amount4")
  ("name5" "amount5")
  ("name6" "amount6")
  ("name7" "amount7")
  ("name8" "amount8")
  ("name9" "amount9")
  ("name10" "amount10")
  ("name11" "amount11")
  ("name12" "amount12")
  ("name13" "amount13")
  ("name14" "amount14")
  ("name15" "amount15")
  ("name17" "amount17")
  ("name18" "amount18")
  ("name19" "amount19")
  ("name20" "amount20")
  ("name21" "amount21")
  ("name22" "amount22")
  ("name23" "amount23")
  ("name24" "amount24")
  ("name25" "amount25")
  ("name26" "amount26")
Message 11 of 19
Lex_van_Ham
I made a script that creates a drawing with blocks, counting the blocks can be done with that script but then i have other parts where the amount of them is defined by values from the script .
(example W / 10 * H)
Message 12 of 19
Lex_van_Ham
I think I can make it now Smiley Happy
Not sure yet but it feels good Smiley Tongue
Message 13 of 19
ВeekeeCZ
Well, get your list the way fits you best.
Anyway, what I've meant was "build a list" - meaning the process that creates a list. If you're feeling lucky to make it by yourself, consider the following as a spoiler.
(defun c:ListBuilding (/ lst)
  (setq i 0)
  (repeat 16
    (setq lst (cons (list (strcat "name" (itoa (setq i (1+ i)))) (strcat "amount" (itoa i))) lst)))
  (reverse lst)
Message 14 of 19
Lex_van_Ham
  (vl-load-com)
  (or *acdoc*
  (or *blocks*
  (if ss
    (progn
      (vla-delete ss)
      (initget 1)
		    20			; cell height
		    80			; row width
      (setq row 2)
      (foreach item refs
	  table
	  row
	  2
	  :vlax-true
	(setq row (1+ row))
  (princ)
Can I please get a bit more explanation on which part of this code does what so I can better modify it to work the way I want?
Message 15 of 19
_gile
(defun c:listBlock (/ ss name block blocks insPt table row)
  (vl-load-com)
  (or *acdoc*
  (or *blocks*
  ;; Select blocks
  (if ss
    (progn
      ;; Build a list of dotted pairs (blockName . numberOfReferences) from the selection set
		blocks (if (setq block (assoc name blocks))
			 (subst (cons name (1+ (cdr block))) block blocks)
			 (cons (cons name 1) blocks)
      (vla-delete ss)
      ;; Prompt for inserrtion point
      (initget 1)
      ;; Create the table
		    (+ 2 (length blocks)) ; number of rows (including title and header)
		    20			; cell height
		    80			; row width
      ;; Fill the titel and the header
      ;; fill the following rows from the list contents
      (setq row 2)
      (foreach item blocks
	(vla-settext table row 0 (car item)) ; block name
	(vla-settext table row 1 (cdr item)) ; references count
	(vla-SetBlockTableRecordId	; block symbol
	  table
	  row
	  2
	  :vlax-true
	(setq row (1+ row))
  (princ)
But, if you're not able to understand such code, maybe you should learn the AutoLISP basics before trying to achieve such task.
We all have to learn how to walk before trying to run...
Gilles Chanteau
GileCAD
GitHub
Message 16 of 19
braudpat
Hello @_gile
Beautiful Routine !
Please is it possible to have a Micro-Micro-Improvment ?
On the command/text Windows : the total of the Blocks ...
Thanks in advance, Regards, Patrice
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 17 of 19
@_gile
Thank for excellence code.
If I don't need 1 st row(Header row), only required the title of row and below data how can do that.
(see attached screenshot)
Message 18 of 19
_gile
@Anonymous a écrit :
@_gile
You should have been able to do it by yourself (look at the commented red lines).
  (vl-load-com)
  (or *acdoc*
  (or *blocks*
  ;; Select blocks
  (if ss
    (progn
      (vla-delete ss)
      (initget 1)
      ;; Create the table
		    ;(+ 2 (length blocks)) ; number of rows (including title and header)
		    (+ 1 (length blocks)) ; number of rows (including header)
		    20			; cell height
		    80			; row width
      ;(vla-put-TitleSuppressed table :vlax-false)
      (vla-put-TitleSuppressed table :vlax-true)
      ;; Fill the title and the header
      ;(vla-setText table 0 0 "Blocks")
      ;(vla-setText table 1 0 "Name")
      ;(vla-setText table 1 1 "Count")
      ;(vla-setText table 1 2 "Symbol")
      ;; Fill the header
      (vla-setText table 0 0 "Name")
      (vla-setText table 0 1 "Count")
      (vla-setText table 0 2 "Symbol")
      ;(setq row 2)
      (setq row 1)
	  table
	  row
	  2
	  :vlax-true
	(setq row (1+ row))
  (princ)
Gilles Chanteau
GileCAD
GitHub
Message 19 of 19
jeguizaASRZM
Hello, Great Lisp!
I had a quick question. How is the size of the text being driven in this lisp routine? Can I Change the text Size to maybe 100? I know I was Able to change the table row sizes, but that's as far I was able to change. I tried to change my TextSize but that also did not work.
Any Comments or help would be appreciated! 😃
