Yes, you can. Many examples can be found in this forum or other forums.
Check the thread below for one of those many examples; my code creates a table with information collected from the drawing in this case.
You can use the ActiveX vla-AddTable function to create the table and the use the Table object methods and properties
Im not sure if its included in your last reply (probably is but i can't find/don't understand it) but how would i use the same lisp script to put text/number/other stuff into the cells like a-2 = 10 or something.
Well, tables are not that simple to handle that after couple of days of learning LISP. Rather post your idea what it should look like and we may help you to make that happen.
Oke so:
I want a table with 2 columns 28 rows with in the top row the table name
Below that the names of the columns
All the rows below that Column 1 will always have the same name with exeption for row 5 and 6 They will be like:
(cond
(Different product
and so on.
Column 2 will be the amount of items based on calculations from my last script.
Example:
Here's an example from which you should get som inspiration.
It creates a table to list the selected block references.
(defun c:listBlock (/ ss name ref refs insPt table row) (vl-load-com) (or *acdoc* (setq *acdoc* (vla-get-ActiveDocument (vlax-get-acad-object))) ) (or *blocks* (setq *blocks* (vla-get-Blocks *acdoc*)) ) (prompt "\nSelect blocks to list or <All>") (or (setq ss (ssget '((0 . "INSERT")))) (setq ss (ssget "_X" '((0 . "INSERT"))) ) ) (if ss (progn (vlax-for x (setq ss (vla-get-ActiveSelectionSet *acdoc*)) (if (not (vlax-property-available-p x 'Path)) (setq name (vla-get-EffectiveName x) refs (if (setq ref (assoc name refs)) (subst (cons name (1+ (cdr ref))) ref refs) (cons (cons name 1) refs) ) ) ) ) (vla-delete ss) (initget 1) (setq insPt (trans (getpoint "\nInsertion point: ") 1 0)) (setq table (vla-addtable (vla-get-modelspace *acdoc*) (vlax-3d-point insPt) (+ 2 (length refs)) ; number of rows (including title and header) 3 ; number of colums 20 ; cell height 80 ; row width ) ) (vla-put-VertCellMargin table 4.0) (vla-put-TitleSuppressed table :vlax-false) (vla-put-HeaderSuppressed table :vlax-false) (vla-setText table 0 0 "Blocks") (vla-setText table 1 0 "Name") (vla-setText table 1 1 "Count") (vla-setText table 1 2 "Symbol") (setq row 2) (foreach item refs (vla-settext table row 0 (car item)) (vla-settext table row 1 (cdr item)) (vla-SetBlockTableRecordId table row 2 (vla-get-ObjectId (vla-Item *blocks* (car item))) :vlax-true ) (setq row (1+ row)) ) ) ) (princ) )
Lets start from the beginning. Are you able to build a list of values for your table? It should look like this:
'(("name1" "amount1") ("name2" "amount2") ("name3" "amount3") ("name4" "amount4") ... ("name16" "amount16") )
And looking at your example table.......what are you exactly counting?
If you are counting blocks in the current drawing or in a set of drawings, this might be easily solved by using the Extract Data tools (Ribbon Insert-> Panel Linking & Extraction --> Extract Data) as this will be able to count and automatically create a table for you.
Like this? If you mean replace the name of "name1" to what ever it will be when done ill do that when I got the entire thing working. '(("name1" "amount1") ("name2" "amount2") ("name3" "amount3") ("name4" "amount4") ("name5" "amount5") ("name6" "amount6") ("name7" "amount7") ("name8" "amount8") ("name9" "amount9") ("name10" "amount10") ("name11" "amount11") ("name12" "amount12") ("name13" "amount13") ("name14" "amount14") ("name15" "amount15") ("name16" "amount16") ("name17" "amount17") ("name18" "amount18") ("name19" "amount19") ("name20" "amount20") ("name21" "amount21") ("name22" "amount22") ("name23" "amount23") ("name24" "amount24") ("name25" "amount25") ("name26" "amount26")
I made a script that creates a drawing with blocks, counting the blocks can be done with that script but then i have other parts where the amount of them is defined by values from the script .
(example W / 10 * H)
I think I can make it now
Not sure yet but it feels good
Well, get your list the way fits you best.
Anyway, what I've meant was "build a list" - meaning the process that creates a list. If you're feeling lucky to make it by yourself, consider the following as a spoiler.
(defun c:ListBuilding (/ lst) (setq i 0) (repeat 16 (setq lst (cons (list (strcat "name" (itoa (setq i (1+ i)))) (strcat "amount" (itoa i))) lst))) (reverse lst) )
Can I please get a bit more explanation on which part of this code does what so I can better modify it to work the way I want?
(defun c:listBlock (/ ss name block blocks insPt table row) (vl-load-com) (or *acdoc* (setq *acdoc* (vla-get-ActiveDocument (vlax-get-acad-object))) ) (or *blocks* (setq *blocks* (vla-get-Blocks *acdoc*)) ) ;; Select blocks (prompt "\nSelect blocks to list or <All>") (or (setq ss (ssget '((0 . "INSERT")))) (setq ss (ssget "_X" '((0 . "INSERT"))) ) ) (if ss (progn ;; Build a list of dotted pairs (blockName . numberOfReferences) from the selection set (vlax-for x (setq ss (vla-get-ActiveSelectionSet *acdoc*)) (if (not (vlax-property-available-p x 'Path)) (setq name (vla-get-EffectiveName x) blocks (if (setq block (assoc name blocks)) (subst (cons name (1+ (cdr block))) block blocks) (cons (cons name 1) blocks) ) ) ) ) (vla-delete ss) ;; Prompt for inserrtion point (initget 1) (setq insPt (trans (getpoint "\nInsertion point: ") 1 0)) ;; Create the table (setq table (vla-addtable (vla-get-modelspace *acdoc*) (vlax-3d-point insPt) (+ 2 (length blocks)) ; number of rows (including title and header) 3 ; number of colums 20 ; cell height 80 ; row width ) ) (vla-put-VertCellMargin table 4.0) (vla-put-TitleSuppressed table :vlax-false) (vla-put-HeaderSuppressed table :vlax-false) ;; Fill the titel and the header (vla-setText table 0 0 "Blocks") (vla-setText table 1 0 "Name") (vla-setText table 1 1 "Count") (vla-setText table 1 2 "Symbol") ;; fill the following rows from the list contents (setq row 2) (foreach item blocks (vla-settext table row 0 (car item)) ; block name (vla-settext table row 1 (cdr item)) ; references count (vla-SetBlockTableRecordId ; block symbol table row 2 (vla-get-ObjectId (vla-Item *blocks* (car item))) :vlax-true ) (setq row (1+ row)) ) ) ) (princ) )
But, if you're not able to understand such code, maybe you should learn the AutoLISP basics before trying to achieve such task.
We all have to learn how to walk before trying to run...
Hello @_gile
Beautiful Routine !
Please is it possible to have a Micro-Micro-Improvment ?
On the command/text Windows : the total of the Blocks ...
Thanks in advance, Regards, Patrice
Patrice BRAUD
Thank for excellence code.
If I don't need 1 st row(Header row), only required the title of row and below data how can do that.
(see attached screenshot)
You should have been able to do it by yourself (look at the commented red lines).
(defun c:listBlock (/ ss name block blocks insPt table row) (vl-load-com) (or *acdoc* (setq *acdoc* (vla-get-ActiveDocument (vlax-get-acad-object))) ) (or *blocks* (setq *blocks* (vla-get-Blocks *acdoc*)) ) ;; Select blocks (prompt "\nSelect blocks to list or <All>") (or (setq ss (ssget '((0 . "INSERT")))) (setq ss (ssget "_X" '((0 . "INSERT"))) ) ) (if ss (progn ;; Build a list of dotted pairs (blockName . numberOfReferences) from the selection set (vlax-for x (setq ss (vla-get-ActiveSelectionSet *acdoc*)) (if (not (vlax-property-available-p x 'Path)) (setq name (vla-get-EffectiveName x) blocks (if (setq block (assoc name blocks)) (subst (cons name (1+ (cdr block))) block blocks) (cons (cons name 1) blocks) ) ) ) ) (vla-delete ss) ;; Prompt for inserrtion point (initget 1) (setq insPt (trans (getpoint "\nInsertion point: ") 1 0)) ;; Create the table (setq table (vla-addtable (vla-get-modelspace *acdoc*) (vlax-3d-point insPt) ;(+ 2 (length blocks)) ; number of rows (including title and header) (+ 1 (length blocks)) ; number of rows (including header) 3 ; number of colums 20 ; cell height 80 ; row width ) ) (vla-put-VertCellMargin table 4.0) ;(vla-put-TitleSuppressed table :vlax-false) (vla-put-TitleSuppressed table :vlax-true) (vla-put-HeaderSuppressed table :vlax-false) ;; Fill the title and the header ;(vla-setText table 0 0 "Blocks") ;(vla-setText table 1 0 "Name") ;(vla-setText table 1 1 "Count") ;(vla-setText table 1 2 "Symbol") ;; Fill the header (vla-setText table 0 0 "Name") (vla-setText table 0 1 "Count") (vla-setText table 0 2 "Symbol") ;; fill the following rows from the list contents ;(setq row 2) (setq row 1) (foreach item blocks (vla-settext table row 0 (car item)) ; block name (vla-settext table row 1 (cdr item)) ; references count (vla-SetBlockTableRecordId ; block symbol table row 2 (vla-get-ObjectId (vla-Item *blocks* (car item))) :vlax-true ) (setq row (1+ row)) ) ) ) (princ) )
Hello, Great Lisp!
I had a quick question. How is the size of the text being driven in this lisp routine? Can I Change the text Size to maybe 100? I know I was Able to change the table row sizes, but that's as far I was able to change. I tried to change my TextSize but that also did not work.
Any Comments or help would be appreciated! 😃
