Lisp stopped working when moved from 2015 to 2016
Hi there.
 My office recently moved to 2016 and a lisp that I have been using previously stopped working and I'm not sure why but I'm inclined to think is just a setting in 2016.  I have attached a copy of the Lisp routine as well as a screen shot of the command line during the command.  (The only other adjustment to the lisp would be each time I start the command it would place ortho on instead of off).
I'm sure the fix is an easy one however elusive to me.
I greatly appreciate your help in the past and now.  Makes a huge impact on my work speed.
thanks again.
;;;;;THIS ROUTINE IS TO PLACE 4x4 SHEAR POSTS AT THE END OF SELECTED SHEAR WALL LINE. REQUIRES LAYERS (S-PLAN-RCOL) TO EXIST AND PATHED TO BLOCK 4X6SHEARPOST
(defun C:4R  (/);(/ *error* doc svnames svvals esel ent edata pt1 pt2 side rot)
   (vl-load-com)
   (defun *error* (errmsg)
     (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break"))
       (princ (strcat "\nError: " errmsg))
     ); if
     (mapcar 'setvar svnames svvals); reset System Variables
     (vla-endundomark doc)
     (princ)
   ); defun - *error*
   (setq doc (vla-get-activedocument (vlax-get-acad-object)))
   (vla-startundomark doc)
   (setq ; System Variable saving/resetting without separate variables for each:
     svnames '(osmode cmdecho orthomode blipmode clayer); list of System Variable Names
     svvals (mapcar 'getvar svnames); get initial Values
     esel (entsel "\nSelect Line at which to add Shear Posts: ")
     ent (car esel)
     edata (entget ent)
     pt1 (cdr (assoc 10 edata)); start
     pt2 (cdr (assoc 11 edata)); end
     side (getpoint pt1 "\nPick to side of Line on which to add shear posts: ")
     rot (* (/ (prin1 (angle (prin1 (vlax-curve-getClosestPointTo ent side T)) side)) pi) 180); ROTation angle for Insert commands
   ); setq
   (mapcar 'setvar svnames '(0 0 0 0 "s-plan-rcol"))
     ; turn off osnap, command echoing, ortho, blips; set Layer
   (command
     "_.insert" "4x4ShearPost"
       "_none" (polar pt1 (angle pt1 pt2) 1.75); half-post-width in from start
       "" "" rot
     "_.insert" ""
       "_none" (polar pt2 (angle pt2 pt1) 1.75); from other end
       "" "" rot
   ); command
   (princ)
 ); defun
john.uhden
I didn't study all the code, but what popped out to me was your attempt to use the function vlax-curve-getClosestPointTo on an entity name.  That Active-X function can be used only on VLA objects, such as (setq object (vlax-ename->vla-object e)) to convert it.
Many of the Active-X functions allow you to access/modify objects much more deeply and easily than dealing with DXF codes.  Practice, practice.
To help you learn more about object properties, here's something I use all the time...
;; Command to "dump" ActiveX data of a non-nested object:
(defun C:OD ()
  (and
    (setq e (car (entsel)))
    (vlax-dump-object object)
    (textscr)
  (princ)
I did not localize the variables on purpose so that I could access them outside the function
John F. Uhden
ВeekeeCZ
Try spoiler...
Spoiler
   (vl-load-com)
     ); if
     (princ)
   ); defun - *error*
     ent (car esel)
     edata (entget ent)
     ip1 (polar pt1 (angle pt1 pt2) 1.75)
     ip2 (polar pt2 (angle pt2 pt1) 1.75)
   ); setq
   (command
       "_none" ip1 ; half-post-width in from start
       "" "" rot
     "_.insert" ""
       "_none" ip2 ; from other end
       "" "" rot
   ); command
   (princ)
 ); defun
