AcCoreConsole Noob
AcCoreConsole Noob
burniksapwet
Message 1 of 10
AcCoreConsole Noob
burniksapwet
Guys, I am trying to understand how to use AcCoreConsole but I already cannot get past my problem of trying to open a drawing.
"accoreconsole.exe /i "C:\Temp\SampleDrawings\Lights.dwg" /s "c:\Temp\PDF_EN\PDFGen_EN.scr" /l en-US"
Typing this out does not work for me because right after I type accoreconsole.exe and spacebar I already get an error of "Accoreconsole.exe unknown command "exe". Press F1 for help.  It always tries to run whatever I type after I hit spacebar. What am I doing wrong? Hopefully the smart people here can help me out better. Thanks.
Replies (9)
Message 2 of 10
dbroad
Where are you entering this command?  It is not an internal AutoCAD command and must be entered in a windows shell or via a batch file.  You must also include the path to the accoreconsole.exe.
Architect, Registered NC, VA, SC, & GA.
Message 3 of 10
burniksapwet
How do I write the location of Accoreconsole.exe?
cd "C:\Program Files\Autodesk\AutoCAD2013"
c:
cls
PAUSE
This is what i am trying to run.  I'm so sorry for the noob question but I am not particularly good at this.  My Accoreconsole.exe is located in C:\Program Files\Autodesk\AutoCAD2013. Thank you.
Message 4 of 10
Ranjit_Singh
If it is located here C:\Program Files\Autodesk\AutoCAD2013 then hold windows key + R and type in there "C:\Program Files\Autodesk\AutoCAD2013\accoreconsole.exe" with the quotes
Message 5 of 10
Ranjit_Singh
If you want to type it in AutoCAD then first type _shell and then at the shell command enter "C:\Program Files\Autodesk\AutoCAD2013\accoreconsole.exe" with the quotes
Message 6 of 10
burniksapwet
So how do I write this properly if I want it to be as a batch? I know what format everything needs to be at, I just dont know how to write the initial process part of saying where my accoreconsole is.
c:
cls
PAUSE
How do I write the script properly on top? I get an error when i do so. Basically it says Accoreconsole.exe is not recognized as an internal or external command, operable program or batch file.
Message 7 of 10
Ranjit_Singh
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation.  All rights reserved.
C:\Users\xxxxxxxx>cd C:\Program Files\Autodesk\AutoCAD 2015
C:\Program Files\Autodesk\AutoCAD 2015>accoreconsole.exe /?
AutoCAD Core Engine Console - Copyright Autodesk, Inc 2009-2013.
Usage:
AcCoreConsole.exe [/i <input dwg>] /s <script> [/l <language>] [/isolate <userid> <userDataFolder>] [/readonly] [/p[rofile] <profile>]
Example:
AcCoreConsole.exe /i 8th_floor.dwg /s test.scr /l en-US
ERROR: Something went wrong. ErrorStatus=53.
C:\Program Files\Autodesk\AutoCAD 2015>Accoreconsole.exe /i "C:\Users\Default\AppData\Drawing4.dwg"
************************MessageBox****************************
AutoCAD Alert
 C:\Users\Default\AppData\Drawing4.dwg is currently in use by :
 xxxxxxxxxx.
Would you like to open the file read-only?
>>>Responding: Yes.
Regenerating layout.
Regenerating model.
Loading Modeler DLLs.
Press ENTER to continue:
Command:
Command:
Command:
Command:
Your batch will be something like this
save the file as whatever.bat
Message 8 of 10
greg_battin
Here is my blog post about how to get up and running with the core console.
https://autocadtips1.com/2013/01/30/up-and-running-with-the-2013-core-console/
~Greg
Message 9 of 10
burniksapwet
This is awesome. Thank you so much.  I have a quick question about the ScriptPro 2.0.  Is there a way to set up ScriptPro 2.0 to always use accoreconsole by default?  I find myself having to always update that. We would like to use this application and automate the process through the network but I dont know if that would be possible if we have to always manually to this.  Thanks.
Message 10 of 10
Here is how I use AcCoreConsole....
BAT file -
echo off
echo Starting AcCoreConsole
c:
cd C:\Program Files\Autodesk\AutoCAD 2013
echo ================================================================================
echo Enter Block Sub-Folder name [F:\Blocks\...]
SET /P dname=Enter F:\Block Sub-Folder name ?
FOR %%f in ("F:\Blocks\%dname%\*.dwg") DO "C:\Program Files\Autodesk\AutoCAD 2013\AcCoreConsole.exe" /i "%%f" /s "F:\Blocks\_FixBase.scr" /l en-US
echo Done!
pause
Note -
This defaults to 'F:\Blocks' folder and allows user to input a subfolder.
You can remove the pause at end if you want.
Here is an example of '_FixBase.scr' script file to change base point of drawing to 0,0,0, zoom extent and purge 3 times
BASE
0,0,0
ZOOM
E
ZOOM
.95X
PURGE
ALL
N
PURGE
ALL
N
PURGE
ALL
N
UPDATETHUMBNAIL
31
UPDATETHUMBSNOW
SAVE
Y
