At work we have an Autolisp where the user enters distances for b, c & d and picks a start point. The lisp then draws a line from start point (pt1) 180 degrees at length d. Then draws a second line from pt1 to pt2 where pt2 = pt1 + [b,c].
We are unable to get the lisp to draw the second line to pt2. We tried two different approaches. See below for the lisp portions not working for both options. Option 1 would draw the second line from pt1 to pt2 where pt2 is defined in the line command using a cal function. Option 2 would draw the second line from pt1 to pt2 where pt2 is set prior to the line command.
The error for option 1 appears as “error: no function definition: CAL”
The issue for option 2 is it prompts to enter another start point for pt1+[b,c].
How can we get the lisp to draw a line from pt1 to pt2?
Option 1
(setq pt1 (getpoint “\nEnter start point: “))
(command “line” pt1 (polar pt1 (dtr 180.0) d) ““)
(setq e1 (entget (entlast)))
(setq e1a (entlast))
(command “line” pt1 (setq pt2 (cal “[@b,c]”)) ““)
Option 2
(setq pt2 (getpoint “pt1+[b,c]”))
(command “line” pt1 pt2 ““)
Solved by Kent1Cooper. Go to Solution.
The cal AutoLisp function is an external one, and must be called with (c:cal ...) -- see Help. [Whether or not you got the rest of the cal expression right, I couldn't say.] But there's a "native" AutoLisp function you can use:
(command “line” pt1 (polar pt1 pi d) ““)
(command “line” pt1 (setq pt2 (mapcar '+ pt1 (list b c))) ““)
Very common way...
(setq pt2 (list (+ (car pt1) b) (+ (cadr pt1 c)))) (command "line" "_non" pt1 "_non" pt2 "")
Also possible... your @b,c ...but limited precision.
(command "line" "_non" pt1 "_non" (strcat "@" (rtos b 2 10) "," (rtos c 2 10)) "")
