lisp routines doesnt work in autocad 2017
Message 1 of 8
Since I changed to Autocad 2017, none of my lisps routines works. They all have fonction errors such as:
- Select object: ; error: no function definition: VLAX-CURVE-GETAREA;
- Select object: ; error: no function definition: VLAX-ENAME->VLA-OBJECT.
I've tried vl-load, but the Command: (vl-load-com), but nothing seems to change.
Do you have any idea of what is going on?
Thanks..
Replies (7)
Message 2 of 8
dbroad
I would suggest a reinstall or repair install.  I haven't installed 2017 yet myself but can't imagine that activeX would be broken.
Architect, Registered NC, VA, SC, & GA.
Message 3 of 8
Hello Professor,
Thanks for your answer. I tried reinstall and repair.. but I get the same error messages.
I searched everywhere and the closest I got from the answer was a sugestion of reprograming all the lisp routines with a new code.. but I´m not an expert in lisp so my solution was uninstalling autocad 2017 and installing autocad 2016.. and it works just fine now.
Message 4 of 8
dbroad
If you feel it is a bug of 2017, you should report it as such through the defect reporting channels. Glad you got your's working.  I haven't installed my 2017 version yet so cannot corroborate.
Message 5 of 8
Try putting in a line of Lisp code at the top of the program.
(vl-load-com)
Bob
EC-CAD
Message 6 of 8
Hello Bob,
I tried that, didn´t work.
Thanks anyway.
Sara
Message 7 of 8
Lineabove
Might be a long shot, but have you installed the VBA Enabler for 2017?
http://tinyurl.com/hjjrceh
Message 8 of 8
I did that too.. Same error message
