Message 1 of 13
- Mute
- Permalink
- Report
I'm looking for a LISP Routine that I could run that will do the following:
1. Run the publish command
2. Allow me to select drawings to publish
3. Rename all to something I type in (i.e. a job number shared by each file)
4. Keep the Layout tab as a suffix (like normal)
The end result would be publishing multiple sheets with the same prefix followed by the sheet number which is matched by the layout tab:
21.0005.00 - E0.01
21.0005.00 - E1.01
21.0005.00 - E1.02
etc.
My company has been doing this manually for some time now, and I am very new to figuring out the coding language. Does anyone know if this can be done?
