Lisp Routine to place fire sprinklers in ceiling grid
averys8YKW6
averys8YKW6
I was wondering if anyone had a lisp routine that could place sprinkler blocks in the ceiling grid/room based of spacing requirements of 15'-0" between sprinklers maximum and 6'-0" between sprinkler minimum, 7'-6" off a wall maximum.
The sprinkler blocks cannot be placed in the same grid tile as a light or hvac diffuser.
I have seen light fixture spacing lisp routines in this forum that could potentially be manipulated to use fire sprinklers.
Kent1Cooper
Sample drawing, please.  For example, I can only imagine that the spacings should be not only between your minimum and maximum, but also at multiples of the grid size, so you won't get a head landing on a grid line, etc.  Is the grid drawn, as a Hatch pattern?  If so, what is the origin of the pattern definition [center of a tile? grid intersection?], and at what scale is the Hatch pattern used [presumably 1 if it's a pattern designed as ceiling grid]?  A routine could find those, and use them and the Hatch rotation to calculate midpoints of ceiling tiles.  What else is there to work with?  A Polyline room perimeter, perhaps?  [That should not be needed if the grid is a single Hatch pattern for the whole room.]  Etc., etc.
I expect the conflicts-with-other-things part will be enormously difficult for a routine, if even possible, so you may need to handle that yourself.  It raises the question:  What takes precedence in terms of spacings?  If moving a head to not be in a light fixture makes the head spacing too great somewhere, then do you try shifting the whole pattern of heads, or moving the light [or the whole pattern of lights] instead, or...?
Kent Cooper, AIA
jtohillVY4VS
The easiest way would be a block spaced with an array 15' x 6' centers.
Sea-Haven
So "I have seen light fixture spacing lisp routines" did you try one of them but with sprinkler blocks ? Like Kent can see all sorts of problems with lights to close. I dont do sprinklers but would think you can go closer than min spacing.
