Message 1 of 16
How to save insert scale factor upon quiting dwg session and use the same scale factor working back to the same dwg
We have this routine to insert block with preset scale factor.
(defun c:ib () ;Insert block name
(if (null _insscl) (setq _insscl 1.0))
(setq BNAME (getstring T (strcat "Enter block name" "<" (getvar "INSNAME") "> :")))
(command "insert" BNAME "s" _insscl pause)
(defun c:ip (/) ;Set insert scale factor
(setq i (getreal (strcat "\nEnter scale factor <" (rtos _insscl 2 3) ">: ")))
(if (/= i nil) (setq _insscl i))
My goal is to save value I entered for 'ip' (scale factor) upon quitting drawing session and use the same value for my custom command 'ib' when reopening the previous drawing. How can I set to remember that value until someone change it?
Thank you!
