Visual LISP, AutoLISP and General Customization
Lisp routine to place Circle to different blocks and count the no of circles placed for each type of block
4 REPLIES 4
nanja_c86
611 Views, 4 Replies
Please help me complete this lisp. Attached the dwg and lisp files.
I need lisp to place circle to all the blocks which are listed in the program and need to count the number of circles placed for each block type and display as a alert message. if any block not found need shows alert msg that this block not found in dwg.
Labels (2)
4 REPLIES 4
ВeekeeCZ
in reply to: nanja_c86
And what's the issue?
(defun c:amp_list (/ s i d n a l)
  (if (and (setq s (ssget "_X" '((0 . "INSERT") (2 . "DA_LE1,DA_DUAL-MINI,DA_TRPLE,DA_QUAD,DA_SNGLE-MINI"))))
	   (if (tblsearch "LAYER" "CIRCLES")
	     (vl-cmdf "_.layer" "_t" "CIRCLES" "_on" "CIRCLES" "")
	     (vl-cmdf "_.layer" "_n" "CIRCLES" "_lw" 0.5 "CIRCLES" "_co" 2 "CIRCLES" "")))
    (repeat (setq i (sslength s))
      (setq d (entget (ssname s (setq i (1- i))))
	    n (cdr (assoc 2 d))
	    l (if (setq a (assoc n l))
		(subst (cons n (1+ (cdr a))) a l)
		(cons (cons n 1) l)))
      (entmake (list '(0 . "CIRCLE") (assoc 10 d) '(40 . 25) '(8 . "CIRCLES")))))
  (and (setq l (vl-sort l '(lambda (e1 e2) (< (car e1) (car e2)))))
       (setq l (cons (cons "AMPS" (apply '+ (mapcar 'cdr l))) l))
       (alert (apply 'strcat (mapcar '(lambda (x) (strcat "\n" (itoa (cdr x)) " " (car x) " circles placed")) l))))
  (princ)
nanja_c86
in reply to: ВeekeeCZ
Dear BeekeeCZ,
Great!
It's working as required. Thank you very much.
One more thing instead of Showing block name in Alert Msg , i need something like this
DA_QUAD & DA_TRPLE blocks to be added and display as Tripple
DA_DUAL-MINI : MB
DA_LE1: LE
DA_QUAD & DA_TRPLE: TRIPPLE
ВeekeeCZ
Ok, fill up the translation list
(defun c:amp_list (/ r s i d n a l)
  (setq r '(("DA_LE1" . "LE")
	    ("DA_DUAL-MINI" . "B")
	    ("DA_TRPLE" . "D")
	    ("DA_QUAD" . "D")
	    ("DA_SNGLE-MINI" . "E")))
  (if (and (setq s (ssget "_X" (list '(0 . "INSERT") (cons 2 (apply 'strcat (mapcar '(lambda (x) (strcat (car x) ",")) r))))))
	    n (cdr (assoc 2 d))
	    n (cdr (assoc n r))
  (princ)
nanja_c86
Perfect. Thanks a lot for the help.
AutoCAD Inside the Factory
