LISP Routine to output measurement for all blocks in a drawing
Hi
I am constantly working with different clients and their differing drawing disciplines. Each time i perform a block extraction using a lisp file (the WBA file from Lee Mac) that writes out each block into a directory. Depending on the client/ their disciplines and size of the store drawings, there may be anything between 50 and 1000 different blocks on a drawing.
Aside from the blocks, i also need to understand what the block dimensions are. Is there a way to measure each block (through ScriptPro maybe) that would output a file detailing width and depth of each block? It's doubtful that the blocks would be polylines.
Thanks in advance
Rich
devitg
 What  block dimensions? , could you upload a block sample?
You can use vla-getboundingbox
