Lisp Routine to explode nested blocks
RGilbert77
RGilbert77
Hello All,
I have found several lisp routines that explode all nested blocks within a parent block, but not the other way. I am looking for a lisp routine that will select all blocks in a drawing, determine if it has a nested block inside and then explode. Continue until no nested blocks remain. Forgive the analogy, but imagine an onion where every layer is a nested block. I don't want the outside layer, I want the most internal layer.
Any help would be greatly appreciated.
Replies (10)
Moshe-A
@RGilbert77  hi,
@RGilbert77 wrote:
Hello All,
if you use that lisp and at select object(s) select all option, does it do want you want?
Kent1Cooper
@RGilbert77 wrote:
... select all blocks in a drawing, determine if it has a nested block inside and then explode. Continue until no nested blocks remain. ....
Just to clarify:  You do want the lowest/most-internal Blocks to remain as Blocks?  That is, not themselves also Exploded if they contain no further nested Blocks?
Kent Cooper, AIA
Moshe-A
@Kent1Cooper ,
You think what i think?
how about block contain 2 blocks each of them contains 3 blocks each of them contain 4 blocks....
who is going to win?! 😀
3wood
You can try EXPLODEALL.
There is an option to keep the last level of block.
RGilbert77
It does not.
RGilbert77
I tried to be as clear as possible.
But yes...that is exactly what I want.
RGilbert77
Is this a standard command?
I just tried it and it's unrecognized.
Kent1Cooper
@RGilbert77 wrote:
Is this a standard command?  I just tried it and it's unrecognized.
Not in vanilla AutoCAD, at least.  >Here< is a link to a place where you can get it.
Kent Cooper, AIA
RGilbert77
@Kent1Cooper This is exactly what I was looking for.
Thank you for your help!
RGilbert77
@3wood This is perfect. Thank you!
