- Mute
- Permalink
- Report
Greetings all,
Pardon my English and knowledge as I know nothing about lisp nor coding in AutoCAD.
I just found a lisp routine somewhere on the net, to draw a Wall combo (wall complete with plastering and hatching) from one point to another point, which I really interested with and found it very useful for my daily work use. Credits to whoever created this lisp 🙂
The lisp routine as below:
WALL(defun c:wall (/ pt1 pt2 pt3 pt4 pt5 pt6 pt7 pt8 len ang angt)
(setvar "cmdecho" 0)
(command "undo" "be")
(initget 1)
(setq pt1 (getpoint "\nChoose the wall starting point: "))
(initget 1)
(setq pt2 (getpoint pt1 "\nDetermine the wall length: "))
(setq lama (getvar "osmode"))
(setvar "osmode" 0)
(setq ang (angle pt1 pt2))
(setq len (distance pt1 pt2))
(setq angt (angtos ang 4 4))
(if (<= (* pi 25) ang)(setq angt (angtos (- ang (/ pi 2)) 4 4)))
(setq pt3 (polar pt2 (+ (/ pi 2) ang) 150))
(setq pt4 (polar pt3 (+ pi ang) len))
(setq pt5 (polar pt1 (+ (/ pi 2) ang) 20))
(setq pt6 (polar pt5 ang len))
(setq pt7 (polar pt6 (+ (/ pi 2) ang) 110))
(setq pt8 (polar pt7 (+ pi ang) len))
(command "PLINE" pt1 pt2 pt3 pt4 "C")
(command "PLINE" pt5 pt6 pt7 pt8 "C")
(command "-HATCH" "P" "ansi37" "10" "0" "A" "A" "Y" "" "S" "last" "" "")
(setvar "osmode" lama)
(command "undo" "e")
I wonder if anyone can help me to refine the lisp, so the outcome will be as exacts as I expected. The original lisp routine will draw a wall combo with very basic properties as all lines and hatching will be assigned to Layer '0'.
I need the wall combo to have the option to specify wall thickness upon creation. Also each lines and hatching will be assigned with a specific layers and color automatically (kindly refer the screenshot below for further understanding).
Any help would be highly appreciated from the bottom of my heart. Many thanks in advance.
