Lisp routine to delete 5 blocks (block1name, block2name, block3name, block4name, block5name) from 100 drawings
frank.cortesWRCXM
Message 1 of 18
frank.cortesWRCXM
Hi lisp experts,
I am lisp beginner. and I am looking for a Lisp routine to delete 5 blocks (block1name, block2name, block3name, block4name, block5name) from 100 drawings.
Can you give me some advice?
Thank you
Replies (17)
Message 2 of 18
pendean
Community Legend
Community Legend
Message 3 of 18
paullimapa
Message 4 of 18
frank.cortesWRCXM
Thank for your response. I have tried those lisp already and they do not work if the blocks are in the layout.
I got this message
If I run the lisp routine in paper space they remove the blocks , but I want to get a lisp to remove the list of blocks with no workspace restrictions (from model space or papers pace). any advice?
Message 5 of 18
paullimapa
(setq ss (ssget '((0 . "Insert") (2 . "Block1,block2,block3,block4,block5"))) i 0)
(repeat (sslength ss)
 (entdel (ssname ss i))
Paul Li
IT Specialist
@The Office
Message 6 of 18
komondormrex
hi,
what do you mean exactly? delete block definitions of afore mentioned blocks and and theirs references or just references of those blocks?
Message 7 of 18
frank.cortesWRCXM
Hi
 I need to remove those blocks and their definitions.
Message 8 of 18
ronjonp
@frank.cortesWRCXM Give this a try:
(defun c:foo (/ a d)
  (vlax-for l (vla-get-layers (setq d (vla-get-activedocument (vlax-get-acad-object))))
    (cond ((= -1 (vlax-get l 'lock)) (vlax-put l 'lock 0) (setq a (cons l a))))
  (vlax-for b (vla-get-blocks d)
    (if	(= 0 (vlax-get b 'isxref))
      (vlax-for	o b
	(cond ((vlax-write-enabled-p o)
	       (cond ((and (wcmatch (vla-get-objectname o) "AcDbBlockReference")
			   (wcmatch (strcase (vla-get-name o)) "BLOCK1,BLOCK2,BLOCK3,BLOCK4,BLOCK5")
		      (vl-catch-all-apply 'vla-delete (list o))
  ;; Relock layers
  (foreach l a (vlax-put l 'lock -1))
  ;; Regen to see changes
  (vla-regen d acallviewports)
  ;; Purge
  (repeat 2 (vla-purgeall d))
  (princ)
Message 9 of 18
paullimapa
and to remove the definitions after the blocks have been deleted use this :
(command"_.Purge""_B""BlockName1,BlockName2,BlockName3,BlockName4,BlockName5""_N")
Paul Li
IT Specialist
@The Office
Message 10 of 18
frank.cortesWRCXM
hi @ronjonp ,
Thank you so much for your help. The lisp works well (blocks located in Model or layout). Maybe because the blocks I want to remove are part of an Xref (my title block key map)? when I run the script, it does not do anything. can you help me with it?
Message 11 of 18
ronjonp
@frank.cortesWRCXM
If the blocks are nested within an xref they can not be directly erased. You'd need to open your titleblocks and remove the keymaps there.
Message 12 of 18
paullimapa
Maybe use Odbx method to open xref grab the blocks and vla-delete
Paul Li
IT Specialist
@The Office
Message 13 of 18
frank.cortesWRCXM
Thank you all for your help. We do not want to open those files..You know that process involves a huge amount of time.
The Lee Mac delete blocks script works perfect as well and  remove them but the idea is not having to select the blocks.
Message 14 of 18
ronjonp
@frank.cortesWRCXM ODBX does not take a huge amount of time and with the code provided you don't have to manually select the blocks?
Message 15 of 18
marko_ribar
@ronjonp
Something is wrong on my side while checking with ODBX... I used your function and feeded it to (LM:ODBX 'foo nil t) like you see in *.lsp I attached at the end... I created Block1,Block2,Block3,Block4,Block5,Block6,Block7,Block8,Block9,Block10 in each DWG - DWG copies... It doesn't matter I used BricsCAD for drawing, just ignore pop up when opening from ACAD...
Error is something like too few/ too many arguments during eval...
Can you see where is the problem - I saw that your function satisfies restrictions for ODBX...
Marko Ribar, d.i.a. (graduated engineer of architecture)
Message 16 of 18
ronjonp
@marko_ribar Untested but I think you need to change this:
(defun foo (/ a d)
  (vl-load-com)
To this so its argument is the ODBX doc not active.
(defun foo (d / a)
  (vl-load-com)
  (vlax-for l (vla-get-layers d)
Lee has quite a few examples HERE.
Message 17 of 18
marko_ribar
Thanks Ron, it worked on my end...
Cheers...
Message 18 of 18
ronjonp
Cheers...
Cheers!
