lisp routine prompts
Message 1 of 26
i have a lisp routine for the wipe out command, it reads like this: (defun c:WI () (command "-layer" "new" "wipeout" "color" "255" "wipeout" "set" "wipeout" "")(command "rectangle" pause pause)(command "WIPEOUT" "polyline" "last" "yes")(command "draworder" "crossing" pause pause "" "f"))
what i need is to put some prompts in here, after it creates the layer, and begins the rectangle command i want it to say "specify fist corner of wipeout" then "specify second corner of wipeout", then when it starts the draw order command i want it to say "select objects to move to front"
i've never had to put in prompts before but I'd like to start, i just need one example to go off of, or at least some direction
thanks in advance for all you help/comments
kenny
Replies (25)
Message 21 of 26
Try commenting out these (temporarily),...
;;;(command "WIPEOUT" "n" "last" "yes")
;;;(command "draworder" "crossing" pause pause "" "f")
.... to see if it draws the rectangle..
Bob
Message 22 of 26
OK, I just tested this in R2006.....
(defun c:WI (/ pt1 pt2)
(setq echo (getvar "cmdecho")
clay (getvar "clayer"))
(setvar "cmdecho" 0)
(if (tblsearch "layer" "wipeout")
(setvar "clayer" "wipeout")
"wipeout" "")
(Setq Pt1 (Getpoint "\nPick first point: "))
(Setq Pt2 (getcorner pt1 "\nPick second point: "))
(command "rectangle" PT1 PT2)
(command "WIPEOUT" "p" "last" "yes");change the "p" to "n" for versions
<2004
(setvar "cmdecho" 1)
(setvar "clayer" clay)
(setvar "cmdecho" echo)
(princ)
wrote in message news:5079666@discussion.autodesk.com...
acad 2004
it seems like it's not drawing the rectangle
Message 23 of 26
this variation seems to work well:
(defun c:WI ()
(command "-layer" "M" "wipeout" "color" "255" "wipeout" ""); Make / Set Layer
(Setq Pt1 (Getpoint "\nPick first point"))
(Setq Pt2 (getcorner Pt1 "\nPick second point"))
(setq Pt3 (list (car Pt2)(cadr Pt1) 0.0))
(setq Pt4 (list (car Pt1)(cadr Pt2) 0.0))
(command "_Pline" Pt1 Pt3 Pt2 Pt4 "_C")
); function
compliments of bob
but it also needs to say "select objects to bring foward" after the word crossing in the draw order command.
thanks again
Message 24 of 26
THAT'S PERFECT!!!!!!!!!!!
CAN'T THANK YOU ENOUGH!!!!!!
Message 25 of 26
You should have seen the rectangle.
Getcorner is made for this.
Did you put p1 in the getcorner function?
Bill
Message 26 of 26
Add this:
(prompt "\nselect objects to bring foward")
.. just prior to:
.. should do it.
Bob
