lisp routine prompts
Message 1 of 26
i have a lisp routine for the wipe out command, it reads like this: (defun c:WI () (command "-layer" "new" "wipeout" "color" "255" "wipeout" "set" "wipeout" "")(command "rectangle" pause pause)(command "WIPEOUT" "polyline" "last" "yes")(command "draworder" "crossing" pause pause "" "f"))
what i need is to put some prompts in here, after it creates the layer, and begins the rectangle command i want it to say "specify fist corner of wipeout" then "specify second corner of wipeout", then when it starts the draw order command i want it to say "select objects to move to front"
i've never had to put in prompts before but I'd like to start, i just need one example to go off of, or at least some direction
thanks in advance for all you help/comments
kenny
Replies (25)
Message 2 of 26
You can try
(prompt "\nSpecify first corner...")
or
(princ "\nnSpecify second corner...")
or
(print "select object to move...")
Message 3 of 26
You can try
or
(princ "\nSpecify second corner...")
or
Message 4 of 26
not sure what this is supposed to do but try this i didnt test it though
(defun c:WI ()
(Setq Pt1 (Getpoint "\nPick first point"))
(Setq Pt2 (Getpoint "\nPick second point"))
(command "rectangle" PT1 PT2 PAUSE "EXIT")
Message 5 of 26
Your best bet would be to use the built in AutoLisp functions.
Instead of (command "rectangle" pause pause), get your points first.
(setq p1 (getpoint "\nPick first corner of rectangle: < pick > "))
(setq p2 (getcorner p1 "\nPick next corner: < pick > "))
Then:
(command "rectangle" p1 p2)
HTH
Bill
Message 6 of 26
the first one almost worked, displayed the text but then did not change the cursor to select the point and when i clicked a point it error out of the command
Message 7 of 26
this worked well except i could not see the rectangle as i was selecting points. which would be fine for me but many people will be using this so it needs to be "dummy" proof.
Message 8 of 26
Message 9 of 26
Change the second getpoint to getcorner
wrote in message news:5079580@discussion.autodesk.com...
Message 10 of 26
this is exactly what is written in my lisp
(defun c:WI ()
(Setq Pt2 (getcorner "\nPick second point"))
when i enter wi on the command line this is what i get:
Command: wi
Layer "wipeout" already exists.
The polyline must be closed and made up of only line segments.
Unknown command "YES". Press F1 for help.
sorry for all the bother but i've never been taught lisp programming and are pretty much self taught, and this is beyond me, but i would definitely like to learn. thanks again for all your help jeff. if you could figure this out i'd owe you a big one. if you need to know what it is suppose to do let me know and i'll let you know.
Message 11 of 26
Try this:
(defun c:WI (/ pt1 pt2)
(Setq Pt2 (getcorner pt1 "\nPick second point"))
(command "rectangle" PT1 PT2)
(command "WIPEOUT" "n" "last" "yes")
(setvar "cmdecho" 1)
(princ)
You're welcome!
wrote in message news:5079613@discussion.autodesk.com...
Message 12 of 26
(defun c:WI ()
(command "-layer" "M" "wipeout" "color" "255" "wipeout" ""); Make / Set Layer
(Setq Pt2 (getcorner Pt1 "\nPick second point"))
(setq Pt3 (list (car Pt2)(cadr Pt1) 0.0))
(setq Pt4 (list (car Pt1)(cadr Pt2) 0.0))
(command "_Pline" Pt1 Pt3 Pt2 Pt4 "_C")
); function
Bob
Message 13 of 26
still getting this:
i'm not a problem in your routine
Message 14 of 26
sorry i mistyped i'm not SEEING a problem in your routine
Message 15 of 26
i get this:
i can't see a problem in the routine
Message 16 of 26
I'm not familiar with the command options in Wipeout.
However, the "last" is definetly a Polyline, and Closed.
Try removing the "yes" or replace it with "".
Bob
Message 17 of 26
the "yes" tells it to erase the polyline the default is "no", kind of like the mirror command, if i just put enter it will not erase the polyline. it appears to me that for some reason it's not drawing the rectangle.
Message 18 of 26
What version of ACAD are you using? This works fine in r2002.
wrote in message news:5079622@discussion.autodesk.com...
still getting this:
Message 19 of 26
is using osnaps out of the question when specifing your points?
Message 20 of 26
acad 2004
it seems like it's not drawing the rectangle
