This routine works up until the point where it needs to insert the attrubutes then it bombs out.
This worked with AutoCAD 2009 but not with 2021.
For example...
Command: (LOAD "K:/HSMOD2006/LISP/RADSTAIR") C:RADSTAIR
Command: radstair
H. Software Systems, Inc. curved stair template
Enter spiral up to (L)eft or (R)ight: l
Enter Flanges (I)n or (O)ut: o
Enter stair plan radius: 41'9-15/16
Enter stair plan chord length (0 if angle based): 0
Enter stair angular sweep (deg): 19.27
Enter the stair rise: 1'0-1/8
(501.938 168.02 0.336325 12.125 7.08034 168.814 168.457 7.08034 504.533 169.249)insert Enter block name or [?] <dsheet>: K:\hsmod2006\lisp\ewfOL
Units: Unitless Conversion: 0'-1"
Specify insertion point or [Basepoint/Scale/X/Y/Z/Rotate/Explode/REpeat]: 0,0
Enter X scale factor, specify opposite corner, or [Corner/XYZ] <1>: Enter Y scale factor <use X scale factor>:
Specify rotation angle <0.0000>: 0
Command: insert Enter block name or [?] <ewfOL>: K:\hsmod2006\lisp\tempLT
Command: 41'-9 15/16" Unknown command "41'-9 15/16"". Press F1 for help.
Command: 14'-0" Unknown command "14'-0"". Press F1 for help.
Command: 19.2700%%d Unknown command "2700%D". Press F1 for help.
Command: 1'-0 1/8" Unknown command "1'-0 1/8"". Press F1 for help.
Command: 7 1/16" Unknown command "7 1/16"". Press F1 for help.
Command: 14'-0 13/16" Unknown command "14'-0 13/16"". Press F1 for help.
Command: 14'-0 7/16" Unknown command "14'-0 7/16"". Press F1 for help.
Command: 42'-0 9/16" Unknown command "42'-0 9/16"". Press F1 for help.
Command: 14'-1 1/4" Unknown command "14'-1 1/4"". Press F1 for help.
Command: RADSTAIR
Unknown command "RADSTAIR". Press F1 for help.
Command: RADSTAIR
Command: zoom
Specify corner of window, enter a scale factor (nX or nXP), or
[All/Center/Dynamic/Extents/Previous/Scale/Window/Object] <real time>: e
Any advice would be appreciated, thanks.
