LISP routine for duplicating multiple layers at once
edrewsSBTV9
Message 1 of 11
edrewsSBTV9
I am looking for a LISP routine that takes all layers in a drawing and duplicates them, while adding a suffix to the layer name.
For example, start with the following layers:
LayerA
LayerB
LayerC
End up with duplicated layers, adding the suffix "- Car":
LayerA
LayerA - Car
LayerB
LayerB - Car
LayerC
LayerC - Car
Replies (10)
Message 2 of 11
devitg
Hi   @edrewsSBTV9 For better understanding, and maybe get further help, please upload such sample.dwg
Message 3 of 11
Kent1Cooper
Try this:
(defun C:LDNS ; = Layer Duplicate with Name Suffix [" - Car" built in]
  (/ lay laylist ldata lname)
  (while (setq lay (tblnext "layer" (not lay)))
    (setq lname (cdr (assoc 2 lay)))
    (if (not (wcmatch lname "0,Defpoints"))
      (setq laylist (cons lname laylist)); put in list of names
    ); if
  ); while
  (foreach lname laylist
    (setq ldata (entget (tblobjname "layer" lname)))
    (entmake (subst (cons 2 (strcat lname " - Car")) (assoc 2 ldata) ldata))
  ); foreach
  (princ)
); defun
All the duplicated Layers get the color, linetype, etc. of the source Layers.  If that's not what you want, it could be made to do it in some different way.
It could be made to ask for the suffix, instead of having it built in.
I assumed you would not want to duplicate "0" or "Defpoints", but they could be included.
Kent Cooper, AIA
Message 4 of 11
ronjonp
@Kent1Cooper  FWIW I'd also exclude xref layers ( not that entmake is going to error on it ) as well as layers that already have the suffix in the event the user runs the code more than once. Without it you'd have a bunch of stuttering -car -car -car layers. 🍻
(wcmatch lname "0,Defpoints,*|*,* - Car")
Message 5 of 11
Kent1Cooper
Yes, good idea.
Kent Cooper, AIA
Message 6 of 11
edrewsSBTV9
Thank you!
Message 7 of 11
edrewsSBTV9
That works, Thank you!
Message 8 of 11
bguyB9HE7
Observer
Observer
Hello! This is an amazing lsp. Is there a way to do it for layers that are selected instead of all? Tried to see if I could edit it myself but was unsuccessful.
Thank you!
Brandon
Message 9 of 11
Kent1Cooper
@bguyB9HE7 wrote:
... for layers that are selected instead of all? ....
Try this:
  (prompt "\nTo duplicate Layer(s) of selected object(s) with suffix added to name(s),")
  (if (setq ss (ssget "_:L"))
    (progn ; then
      (repeat (setq n (sslength ss))
        (setq lname (cdr (assoc 8 (entget (ssname ss (setq n (1- n)))))))
        (if
          (and
            (not (member lname laylist)); not already in list
            (not (wcmatch lname "* - Car")); doesn't already have suffix
          ); and
          (setq laylist (cons lname laylist)); then -- put in list of names
        ); if
      ); repeat
      ); foreach
    ); progn
  ); if
  (princ)
); defun
I assume you will similarly replace the suffix with your own,  It could also be made to ask for that each time, rather than have it built in.
Kent Cooper, AIA
Message 10 of 11
Sea-Haven
Lee-mac has a double List box function so you could have all your layers in the left side and select which ones you need to change, building a list of layer names in right side. Needs to have the add suffix part added, ran out of time.
Message 11 of 11
bguyB9HE7
Observer
Observer
Wow thank you so much for the help and replying!! Will give this one a go.
